can any one tell me more and where i can find one and if it is SVA pass able?
[Edited on 12/9/07 by Arthur T]
The New VW Passat have them so must be...
There's apparently quite a few cars with electric handbrakes.
Not sure about sva but I don't see why it should fail.
any idea where i find one?
Try looking for a scrapped renault megane scenic, we had one on our old one an 05 plate. I think renault have been using them for a few years, really weird to get used to.
is the merc system electronic?
Jags have them.
I believe its a solinode that holds the handbrake off, you still have to have a manual operation as in no fluid to leak out.
Regards Mark
Lots of cars have Eelectric Parking Brake these days, particulary ones with flappy paddle gearboxes. You have a button on the dash rather than a
lever on the tunnel. The good points are that it is always put on enough (not just 3 clicks from a lazy driver) and that there are no cables to
adjust. The bad point is that you’re stuffed if the battery goes flat.
I thought they were stepper motors rather than solenoids. Could be wrong.
If you do a search under 'Linear Actuator' you will find a few different options. They are basically a stepper motor connected to a
gearbox and can exert over 100Nm of force.
At least one member here produced an electric handbrake and passed SVA.
I don't know much about electrics, but there was a discussion of the type of motor used due to keep the wheels locked after 12v had been switched
off (or the other way...)
Joao
somehow that idea scares me
it can work in one of 2 ways; powered to keep handbrake on but if battery goesd flat or you loose a connection, your car rolls away.
or power to disengage it - so what happens if a battery lead goes astay when you are driving?
or some other way?
Ok, so a cable operated brake isnl;t going to anyting when driving but could snap when parked but I still feel safer with one.
We took a car for sva last week and whilst there i was talking to the tester about handbrakes. He was saying they are nearly always the weak point on
the braking system. I was asking particularly about hydraulic but the official answer was that it has to be mechanical!!!
Oh, The car passed 1st time. It was a RAW striker at cardiff SVA centre. Thanks Russel!
Ben.
I passed SVA with my 12v electric handbrake and it worked fine. Push button down to apply and push again for off. It used a wormdrive actuator so when
the power was off it would hold something like 300kg pull on the cables so ample.
The one on my Cmax sounds like a worm drive also it goes on when you take the keys out the ignition so safe in that respect.
When applied if you loose power you have a cable release accessable through the centre console
New Merc, VW and Audi ones are controled through an ECU and need special access tool to reset. Haven't come across one yet; just heard via trade
press.
adrian
The Jag one uses screw actuators at the rear of the car and short cables to the hubs.
However you cant pull HBT`s with them (
has anyone got any pics of an electric handbrake system? or where i can get the bits? i've been stuggling with working out how my handbrake
system will work. an elctric system would work quite well...
I've got nowhere to mount the hand brake lever itself, the cable routing is not easy and electric acuators on the back axle working on short
cables would be an interesting idea
either that or a brake disc on the prop shaft, but still, where to mount the handle?
