Having a big clearout - lots of bits for sale -
http://www.ebay.co.uk/sch/davidimurray/m.html?_nkw=&_armrs=1&_ipg=&_from=
Just looking through the bits for sale and saw you had a fuel pump blanking plate.
I'm just building up my pinto with bike carbs, I take it you need to blank off the original fuel pump?
If your going bike carbs best to use a bike fuel pump as the pressures are correct otherwise you may need another regulator. Use bike pump, set correctly and chuck away mechanical pump to save some weight and everyone's happy
Yep got a bike fuel pump so will fit that cheers
