Replacing the oil squirters/cooling jets on a blacktop zetec and just wonderring if anyone knows where to get them?
Try Ford directly - I have a feeling it might be one of those parts that's pretty cheap from a dealer.
Question is why are you replacing them? Not really an easy part to wear out?
Because I want to start with an engine I know is good. No point turning up to a race with an unknown engine
If the jets are the same as a Renault Turbo engine, then the jets will be fine, its just the springs behind them you want to replace. This will save you some £££.
