fuel filler hose
2b_pablo - 5/3/08 at 10:11 AM
quick Q re the hose you get to run from the filler cap to the tank.
Im looking at fitting this tank:
Now the filler end is ok as the hose goes over the filler housing but at the tank end if I put the hose over the tank inlet pipe then will petrol seep over the sides of the pipe?
or is this not really a problem? I presume a big jubilee clip is whats used to secure the filler pipe onto the pipe tank?
cheers all
tegwin - 5/3/08 at 10:18 AM
Get a nice tight bit of hose (ooh nurse)....and a big jubilee clip and it shouldnt weep atall
2b_pablo - 5/3/08 at 10:21 AM
perfect thanks, I could use 2 jubilees? one midway and one up at the top of the inlet pipe
/blond moment
tegwin - 5/3/08 at 10:41 AM
If its a tight fit, one would do..
But there is nothing wrong with having two....better safe than sorry I guess
