is there specail termainals for the above
the closest i could find were the small speaker wire terminals but they still are slightly to big and fall of the switch
can any one recommend the correct type
thanks simon
got my terminals from mac#1 and some inslated covers aswell. seem very secure
You can solder them, that is what the hole is for. If you ever change the switch, all you have to do is unclip the front etc.
The speaker terminals do fit quite well if you just tweak them up with a small pair of pliers first.
Hi
we found the terminals on vehicle wiring products.
IIRC I think the 2.8mm ones are the ones that fit but you might want to measure the pins to check.
pre insulated
non insulated
HTH
Ed
Normal small red cased crimps fit fine. Think you can buy them at Halfords.
Pat...
