Hello guys, what the best way to remove a locking wheel bolt without a key? Weld a nut on Bang a socket on etc. it's on a pug 307 with genuine
alloys. Cheers
[Edited on 31/1/14 by Nurburg2006]
I usually bang a socket on, My 17mm sockets had a hard life
If you have Halfords life time warranty ones then you don't need to worry about breaking them
Originally posted by Nurburg2006
Hello guys, what the best way to remove a locking wheel bolt without a key? Weld a nut on Bang a socket on etc. it's on a pug 307 with genuine alloys. Cheers
Dont pay for someone to do it!!
mazie on here did and they damaged his alloy, a right monkey!!!
Get yourself a gator grip.
Will a gator grip fit?
Its worked for me before, but it depends on the type and size of the bolt, and the size of the hole in the wheel (if its recessed down a hole).
[Edited on 31-1-14 by loggyboy]
You can try one of these things
Linky
If I had spare bolts then nut over the top, quick buzz with the welder would be my choice, it's free
Regards Mark
Originally posted by mark chandler
You can try one of these things Linky
But got it fixed quite quickly.
First go was chisel off the outer sleeve/ring on the locking bolt, but the hole in which the bolt sits was quite tight, so likely to damage....
Second go was weld on a bolt, jobs a good 'un. Done by a local 'old guy in a rented unit' type garage, great old boy, no damage,
charged £45 which I thought was reasonable (they were very very stuck!), happy for him to do it.
Find someone trusted/recommended and you should avoid the bad luck others have had.
Ad
loosen all the other bolts and take the car for a good thrash, it'll soon come loose.
Rather than breaking the outer ring with a chisel, you can heat it up by welding onto it. That expands it enough that it just falls off A blow torch would probably work too, but would take most of the paint with it!
Sorry for stupid questions, but...
Why are you trying to remove without Key?
Why not post a pic and get a loaner or buy one from the crowd at LCB?
Regards
Angel Acevedo
It's a mates car trying to help him out
Job done cheers for all the replies chaps
Welded a bolt on
