Can anyone remind me what length coilovers I need for a live axle bike powered 1995 striker.
Also what springs would be best for a track day sprint hillclimb car.
My fronts are 12.5" and my rears are 14" centres.
Mines a cec with 140 rears and 200 front which I believe is a lot softer than most run but it suits me
Ok thanks
So 12.5 wouldn’t work on the rear.
See the protec coilovers for sale on here and see what you think
You could purchase extended top eyes to get an extra 2 inches
Top eye
Ok
Top eye
old strikers had the same length fitted front & rear...even often the same spring rate 135lbs/inch...which are good for rear, but a bit soft for a car-engine. this said...due to the rocker-suspension sylva´s need quite soft springs in front compared to a typical outboard-coilover seven
