Not shaw what to do now had car on dyno only to find out clutch was slipping at 210BHP and revs going into red line. I am running std 2.0L pinto
clutch at present. Should i go to a paddle plate ?.
(THANKS TO MATT AT MTECH.)
[Edited on 13/4/09 by madteg]
don't know is it would fit but how about a cosworth clutch ?
have you ever used a paddle clutch before? they can be a bit harder on the left leg, and are more snappy than a normal clutch. im sure there will be tuners out there that sell uprated clutches that arent paddle type
Will have a shop around, where would you suggest to look
Burtonpower??
My Son got a paddle clutch from Larkspeed for his sierra cosworth and it felt just like a standard cossy clutch
good price too
ps that was about 5 years ago
[Edited on 13/4/09 by jacko]
210 bhp with some slip! wow
From where I was standing beside the rolers it looked like it was spinning the wheels when the turbo kicked in rather than the clutch spinning.
Does it slip on the road?
Have noticed it slipping in fourth on full boost a couple of times but only very slightly, obbiously the dyno puts it under more load.
What about some sort of diesel clutch plate ? Designed to take more torque
http://www2.qha.com/catalogues/QH08.pdf
Just look for soemthing with the right dimensions / splines etc
an organic one should do you i would have thoughm better than standard but not a fierce as a paddle, i used to use a helix one, now im using an ap one
