Supercharging duratec vs cossie
Calzonii - 2/6/15 at 11:13 PM
Would I be right in assuming to supercharge a 2.0l dutatec I would need to replace all engine components and re-port cylinder head?
Pistons
Crank
Conrods
Valve springs
Rockers?
Cams?
Also if I bought a cossie engine would I need to do this? Or would these components in a cossy engine be uprated enough to accept a supercharger without needing changed to forged/strengthened internals?
So maybe a cossy is better option overall?
[Edited on 2-6-2015 by Calzonii]
jeffw - 3/6/15 at 05:18 AM
When you say Cossie do you mean the Cosworth engine in the Sierra/Escort? That is very old tech now.
Speak to Omex, TTS Performance and Raceline and then look at your options.
CosKev3 - 3/6/15 at 05:31 AM
Pretty sure you can supercharge most engines running low boost without any internal engine mods.
if you go high boost you need to lower compression/forged pistons etc.
BaileyPerformance - 3/6/15 at 07:10 AM
Cosworth YB is still the best for big bhp. It's a great engine and is now back in production.
A standard 2WD 205 engine will make over 300bhp without any internal mods. Steel crank, steel rods and forged pistons as standard.
The problem is most cossy engines found second hand are most likely worn out, and can be expensive to rebuild.
SJ - 3/6/15 at 07:13 AM
Depends on the power you want. Flak Monkey on here built a super charged Duratech. Iirc his mods were forged pistons, cams and ARP bolts. I think the rest of the internals were standard but I could be wrong.
Stu
Oddified - 3/6/15 at 08:21 AM
I have a rotrex supercharged cossy in my Kitten. It was modified as a NA engine before i fitted the supercharger so it already had a ported head/cams/solid lifters etc. I've slowly been increasing the boost along with other mods and now i'm running it at 1bar it does go quiet well
The cossy is a bit dated, heavy and expensive but they're strong even as standard. The duratec is newer, lighter, cheaper but not as strong and if you want to make one as strong/reliable (for decent power, say 300+) it'll cost you as much as a standard cossy which can do that power all day long.
Ian
BaileyPerformance - 3/6/15 at 08:47 AM
Agree
If its big power you want then a YB all day...
https://www.youtube.com/watch?v=R3aKb92UCZo
jeffw - 3/6/15 at 09:09 AM
But he doesn't want big power. Stock Duratec with a supercharger will make 260-280BHP all day long. Change the rods/pistons/cams and flow the head you are into 450-500BHP territory.
Of course a F20C from a S2000 with a Rotrex on it (otherwise completely stock) will do 350BHP.
Calzonii - 3/6/15 at 09:26 AM
Yeah, I had sorta thought that by the time I opened up a duratec and changed parts it would cost me as much as a cosworth. What are the new cosworths are they still cast block?
Maybe looking at an S2000 engine or something with a bit more raw power would be the way forward.
What internals do you need to change when supercharging is it just as follows?
Piston
Rods
Crank
Re-port head
Anything else needed to change? Do you have to change cam and lifters etc?
jeffw - 3/6/15 at 11:56 AM
Depends how far you want to go. You can supercharge a stock engine and get mid-200s out of a Zetec or Duratec. Or you can do everything and get 400-500BHP. Pays your money....
Duratec would be lighter than the Zetec but you would still have the issue of gearbox as even the HD Type 9s (BGH, Quaife/Trans-X etc) are at their limits with 250-280 ft lb or so.
BaileyPerformance - 3/6/15 at 01:24 PM
Piston
Rods
Crank
Re-port head
Everyone says thay don't want big power, then after 6 months thay are back looking for more! Always best to aim high and turn the boost down if need be.
wylliezx9r - 3/6/15 at 01:24 PM
Piston
Rods
Crank
Re-port head
You don't need to do modify the internals on the S2000 engine unless you are going silly power. They will do 500 bhp on standard internals (which are forged) and standard gearbox. The only thing that needs to be done is uprate the clutch.
Calzonii - 3/6/15 at 02:20 PM
S2000 sounds well juicy.
I think i might go for that. Are theyre many people on here building Indy's with S2000? Because not doubt I will need advice! Lol
wylliezx9r - 3/6/15 at 02:35 PM
I've put one into a modified Haynes chassis which is similar. Any questions ask away.
Calzonii - 3/6/15 at 02:43 PM
Wyllie, Ill maybe send you a U2U asking you a few questions later. When I get out of work... If it ever ends..
Wht price would a decent S2000 engine run me. I know very little about them!
daniel mason - 3/6/15 at 04:59 PM
They fit in the mnr chassis with standard sump and 6 speed box and diff. Give mnr a call and they will make all mounts for it!
All I did was a bonnet scoop but I think I could have just about got it in without
Mr C - 3/6/15 at 07:30 PM
I've gone the supercharged Duratec route.. only because I was only ever going to add bodies and cams, then decided that I needed forced induction. I spoke to TTS and a few of the others Jeff mentioned. Internals I've Cosworth pistons running 10:1compression helped with a thicker Cometic HG. I used new standard head bolts. There's two schools of thought on the use of ARP studs / bolts being for and the other being against as they can cause distortion under high loads/power by not being able to expand at the same rate as the alloy head/block. The fiesta hi port head breathes a bit better so that was my starting point. Stage 2ish cams, anymore and the duration/overlap can affect the boost I added heavy duty springs to be on the safe side.
New forged rods, mains and big end bearings, and ARP big end bolts. Standard mains bolts as ARP studs don't fit with the Raceline sump and windage plate and also I'm in the against camp for the Duratec anyhow. The standard rods are pretty well at the limit around 220-230 bhp allowing for a reasonable safety margin, though I've heard of some getting considerably more but its not for me.
700cc injectors and a mustang V8 throttle body on a R300 cast alloy plenum sorts the fuelling and air along with the rotrex C30-94 supercharger. Projected BHP around 400 though I'll be happy with around 330bhp running a slightly reduced boost.
In hindsight an S2000 lump and the Supersport kit from TTS giving around 400bhp would have been a good, though slightly more expensive option.
