Q Plate Decat ECU Question
ChrisJ15 - 22/2/26 at 09:02 AM
Hi,
I've noticed a leak around one of the welds going into my Catalytic convertor.
because of a lack of space the guy that built the exhaust positioned the O2 sensor so it points down to the ground and is very low.
Being on a Q plate I dont have emissions tested so thought about killing two birds with one stone:
1) Remove the Cat
2) Move the sensor to the D Cat pipe where it's pointing up and away from the ground
What I don't know though is would I need my ECU remapped?
coyoteboy - 22/2/26 at 10:49 AM
How is your fueling calculated, air flow meter or speed density calculated? Is it using wideband feedback for closed loop?
Speed density is not tolerant to breathing changes so would need a remap. If using an afm it will be happier than the other but still ideally you'd remap.
[Edited on 22/2/2026 by coyoteboy]
ChrisJ15 - 22/2/26 at 11:44 AM
Hmm, not sure. Its an Omex 600 and I know I dont have an airflow meter.
coyoteboy - 24/2/26 at 11:35 AM
Speed density then I expect, so any significant airflow changes will likely need a remap.
ChrisJ15 - 24/2/26 at 02:27 PM
OK good to know thanks.
I guess next question is what sort of extra power would I get decatted and remapped to justify remapping cost?
It's a shade under 200bhp now (2.0 Duratec)
coyoteboy - 25/2/26 at 12:48 PM
I'd have to pass over to others with more knowledge of that engine to be honest, but I'd suspect in the order of 5%. I was approaching it more from the perspective that if you don't remap you'll be running wrong AFR even if you don't make more power.
