<<  1    2  >>
Author: Subject: Brake bias adjustment question
dome
posted on 28/2/16 at 06:12 PM Reply With Quote
Originally posted by alfas
thats what i wanted to say......
majority of cars me and my mates have bought in the past 10years would not have passed another MOT straight after purchase, even those cars passed the MOT a few days before...and i´m not talking about stupid little details...some of the cars had really severe faults.
anyway...back to the thread.
Agreed, I'm under no illusions about the MOT test nor some of the work carried out by previous owners. The pedal setup looks original though, hence it being worth trying the car when the front brakes are fixed and getting it tested by my tame garage. I'm also going to remove the plumbing for the hydraulic handbrake as I'll never use it.
mcerd1
posted on 29/2/16 at 08:58 AM Reply With Quote
Its quite likely that the car was originally built using a single master cylinder (either from the donor car or a similar one, there are loads of threads on here about picking the best one)
Then its likely that this was 'upgraded' at the same time as your hydraulic handbrake was added, both of these would have failed an SVA test
Not that it helps you any, you're still going to need to sort it one way or another...
The bias bars you can get from the likes of rally design are pretty cheap so my vote would be to fit it now and save alot of messing about with the current setup - it'll also give you more flexibility for any brake upgrades you may want to fit later
Did you ever manage to find any clues to the master cylinder sizes that have been fitted?
If they aren't different sizes then they probably should be, if they are different then there is a good chance someone's plumbed then in the wrong way round...
the size is often marked on the sides, 5/8" [0.625] and 3/4" [0.75] are common for quite a few cars, the smaller one should be connected to the front brakes as per the comments above
If they are the wrong way round then correcting this would go a long way to sorting the problem, but without the bias bar for the fine adjustment you'll be very very lucky if its 100% right
[Edited on 29/2/2016 by mcerd1]
adithorp
posted on 29/2/16 at 10:23 AM Reply With Quote
There's absolutely no point putting that back together; You'll only have to do it again.
The slight leak from the calipers will not be significant enough to account for the imbalance (it'd have to be pouring out). You need a proper balence bar. You'll have to set it by trial and error as set of MOT brake rollers won't give that, due to not having weight transfer (at IVA/SVA it's a much more complex test and they do a calculation for the F/R balance). Starting with the bearing dead centre will give the same balance as before. Slightly to the front cylinder will be where you probably end up.
http://jpsc.org.uk/forum/
Angel Acevedo
posted on 1/3/16 at 03:17 PM Reply With Quote
Dome.
If I were you and have access to a lathe, I´d turn the "Bushing" to the Pedals tube diameter and reassemble.
Then go testing for balance at a private road.
If you run out of travel, then switch cylinders as stated somewhere above.
HTH
Edit to correct OP Name.
[Edited on 3/1/2016 by Angel Acevedo]
<<  1    2  >>
