Pigsy
posted on 10/6/19 at 06:02 PM |
Sound logic and a good price to boot. The MG is a lot lighter than the Focus. About two thirds the weight. I am running ~Suzuki itb's which
might give it 190bhp at a push.
Thanks again.
big_wasa
posted on 10/6/19 at 06:36 PM |
Yeh but only around 150ft/lb torque.
They slip on a turbo Zetec putting out 220~250ft/lb +
Pigsy
posted on 10/6/19 at 07:38 PM |
I think I will be ok. Not much of a tyre fryer. I’m not blowing the engine or anything like that.
Pigsy
posted on 11/6/19 at 07:12 AM |
st170: Max torque (lb ft @ rpm) 144 @ 5500.
Pigsy
posted on 11/6/19 at 07:18 AM |
The clutch will take 132 ft/lb in the mondeo 4x4
Pigsy
posted on 11/6/19 at 05:16 PM |
I missed that clutch kit. Will an RS Turbo Ford CVH 220mm fit? its a 220mm diameter. ive seen one at a reasonable price.
Pigsy
posted on 11/6/19 at 05:27 PM |
The 220mm is not the clutch diameter but the flywheel diameter. Forget I asked.
big_wasa
posted on 11/6/19 at 05:35 PM |
Your making hard work off this for your self.
The 220mm cover plate isn’t going to mount to a 240mm flywheel. Have a look at some on line photos and you will see why.
Pigsy
posted on 11/6/19 at 05:41 PM |
Hi. I realised as soon as i asked, hence my last comment. Im just want to be sure that what I fit will take the torque and hp. Im just learning what
is best, all be it slowly. I know 60's and 70's fords, not later. Thanks for helping.
big_wasa
posted on 11/6/19 at 05:48 PM |
I would prefer a brand name but knock of postage and it doesn’t get any cheaper
https://www.ebay.co.uk/itm/NEW-CLUTCH-KIT-FOR-FORD-COUGAR-FOCUS-2-0-MK1-MONDEO-MK2-2-0-1996-to-20005/163490440769?hash=item2610ca2641:g:4H4AAOSwUP5cP0
~D
big_wasa
posted on 11/6/19 at 05:54 PM |
Like I say there are plenty of zetecs on throttle bodies running a standard 1.8 flywheel and Oem clutch. You know have a 2.0 flywheel. Get a matching
clutch and you only have to play with the slave cylinder / clutch fork pivot a little.
Pigsy
posted on 11/6/19 at 06:08 PM |
Thanks. Removing the box on the MG is a real trial and best avoided.
Pigsy
posted on 11/6/19 at 09:46 PM |
Just ordered CLUTCH KIT FOR FORD COUGAR FOCUS 2.0 MK1 MONDEO MK2 2.0 1996 to 2005. £37.95.
The previous one suddenly found they had no stock!!!! Ho hum!
Pigsy
posted on 11/7/19 at 03:42 PM |
Hi Wasa . Im so pleased to say that after a two week break, I have fitted the Cougar/Mondeo flywheel and clutch complete. It works very well. Its
highlighted a leaking master cylinder but that is a quick replacement. Thanks very much for your help!!!!
big_wasa
posted on 11/7/19 at 05:22 PM |
Glad your sorted.
