iiyama
posted on 24/3/09 at 09:16 AM |
Sierra brake pads
Picked up a set of Sierra calipers last year just in case the Hi spec items I had fitted failed SVA. Well SVA man did fail the Hi Specs so I need to
fit the Sierra items.
Basically I know nothing about what I have and I need a set of pads for them. Are all Sierra pads the same? If not how do I identify what calipers I
have?
If its broke, fix it. If it aint broke, take it apart and find out how it works!
mcerd1
posted on 24/3/09 at 09:25 AM |
I think all the sierra rear pads are the same
if they are the calipers you got from me - just ask for rear pads for an XR4x4 (and if they insist on details say its a 1989, 2.9L )
[edit]
ebc's website (look at the models listed in the yellow bit)
http://www.ebcbrakesdirect.com/search/default.asp?part=dp571&v1=car&t1=
they are all (inc 4x4 and 2wd cossies) either a 571 (with wear indicator) or 617 (without wear indicator) pad in various compounds
[Edited on 24/3/09 by mcerd1]
vinnievector
posted on 24/3/09 at 09:30 AM |
hi
Hi mate , your calipers hould have a number on them ,but if you know the age of the car you took them off unipart should be able to help ,
You now have me worried about my brakes as i have fitted willwoods ,and also have to take it to the botley testing station .
Wot did they fail them on .
vinnievector
posted on 24/3/09 at 09:34 AM |
Panic over
Panic over thought you were talking of your front calipers .
Do you have Hi specs fitted to the front and did they pass ok
nstrug
posted on 24/3/09 at 09:40 AM |
They're all the same - just use the flip chart at Halfords.
Nick
iiyama
posted on 24/3/09 at 09:49 AM |
They are the very same, couldnt remember who I got em from! LOL! Gettin senile I think!
Vinnie, got Hi Specs front and rear. Rear are the Ultralight 2 handbrake calipers and they failed because the inner pads operate hydraulically at all
times, even with the handbrake. Basically SVA man dosent like it because "what happens if you get a hydraulic leak?" he asks. "Same
thing that happens if the handbrake cable snaps", was my reply. He didnt buy it so I failed.
Cheers guys.
mcerd1
posted on 24/3/09 at 09:57 AM |
well it was nearly a year ago now
I should add that the only reson for asking for XR4x4 pads is they are easy to find in the book at the motorfactors (and you don't get cossie
tax)
iiyama
posted on 24/3/09 at 11:49 AM |
£14 from Halfrauds.....marvelous!
iiyama
posted on 24/3/09 at 12:36 PM |
Next question.....how the hell do you fit em???
mcerd1
posted on 24/3/09 at 12:47 PM |
I'll send you some stuff later......
or have a look here: linky
iiyama
posted on 25/3/09 at 08:58 AM |
Sorted, Thanks for the link!
