vinnievector
posted on 8/11/09 at 11:21 AM |
throttle cable
Hi ,i would like to pick your brains on throttle cable to peddle attachment , returns routing springs etc and cable adjustments, pics and ideas
please on your mk indy . vin
lotusmadandy
posted on 8/11/09 at 01:21 PM |
I used a universal kit bought from mk for
£4 to fix the cable to the peddle.
As regards return springs and routing,
it depends on what carbs/injection you are fitting.
I have bike carbs on a zetec and have used the cable adjuster from the bike.
I have fitted a return spring where he return cable goes and hooked it onto
the return cable outer fitting(if that makes any sense)
austin man
posted on 8/11/09 at 01:57 PM |
Whatever method you use its essential the the mounting on the pedal end can pivot otherwise the cable will snap over time. I would also suggest
running 2 cables 1 as a back up if one fails as done on the webber set up.
Im using standard bike brake cables for my twin 40 set up. No problems in 3 years of running
vinnievector
posted on 9/11/09 at 11:48 PM |
Thanks for the reply Hi to lotus .
