Author: Subject: puma 1.7 vct help
Stuart_B
posted on 28/8/10 at 06:37 PM Reply With Quote
puma 1.7 vct help
hi all, i need some help on a puma 1.7 vct, the problem is that the part,or parts of the vct are missing on a engine, just wondering what on earth it looks like, or what parts to try to source.
as all the pictures i see have the plastic cover in front so i can not see it.
any one got some pictures or even the system laying around they need to sell.
cheers
stuart
Madinventions
posted on 28/8/10 at 06:41 PM Reply With Quote
Never had the cover off mine, but look here quickly!
>>link<<
Ed.
View my band website:
http://www.shadowlight.org.uk
Stuart_B
posted on 28/8/10 at 06:47 PM Reply With Quote
hmm, 50 postage, no bad.
could use that as parts
beaver34
posted on 28/8/10 at 08:08 PM Reply With Quote
mega money new i can tell you that, like all puma parts
Criddy
posted on 29/8/10 at 03:05 PM Reply With Quote
I'm building a Tiger Avon that will be powered by a 1.7vct PUma engine. There are some difficulties that you will encounter if your going rwd
Stuart_B
posted on 29/8/10 at 04:10 PM Reply With Quote
hi, yep it is going rwd, could be tell me you setup?
i ordered the bell housing last night, got a engine engine sitting in there, and a mx5 engine,box,ecu,wiring loom, and propshaft
and then changed of mind again.
stuart
beaver34
posted on 29/8/10 at 10:59 PM Reply With Quote
machine crank for spigot bearing
you may have an issue with vct ecu dependant aswell
Stuart_B
posted on 30/8/10 at 02:45 PM Reply With Quote
hi, crank machining? for the spigot bearing, have you got any more info on that, or is just get the spigot bearing and send it off to get it done?
cheers
stu
beaver34
posted on 30/8/10 at 08:15 PM Reply With Quote
cheers
stu
yes belive so,
get intouch with shawspeed, as there are no data provided by ford on refitting crank as there not supposed to be removed
Criddy
posted on 30/8/10 at 11:34 PM Reply With Quote
I'm still looking into the spigot bearing issue but as for the VCT that is not a problem. I will be using an OMEX 600 and using the VCT much like a V-Tec in terms of how they will work
