dan__wright
posted on 1/9/10 at 08:49 PM |
omg - flatshifter!
Took the car for the first drive after fitting the trick shifter, its bloody brilliant! I only used the downshift once but the auto blip is cool. I
cant believe how smooth the flatshifts are
FREE THE ROADSTER ONE…!!
coombed
posted on 1/9/10 at 09:23 PM |
I'd never heard of it until I have just googled it. Sounds/seems pretty cool! Did you fit it yourself? What gearbox do you have fitted in your
car?
Dunc
[Edited on 1/9/10 by coombed]
You don't stop playing when you grow old, you grow old when you stop playing!
eddie99
posted on 1/9/10 at 10:12 PM |
How easy was it to fit? Im guessing it was the flatshifter Pro?
http://www.elitemotorsporteng.co.uk/
Twitter: @Elitemotoreng
Facebook: http://www.facebook.com/pages/Elite-Motorsport-Engineering/153409081394323
NigeEss
posted on 1/9/10 at 10:17 PM |
car?
Dunc
Ah...you have much to learn Grasshopper !
Dans info-panel says "post SVA tweaks to ZX10 MK Indy R"
so it's a Kawasaki ZX10 bike engine and thus uses the bikes 6 speed sequential box.
coombed
posted on 1/9/10 at 10:28 PM |
(Hangs head in shame!)
It's amazing what you discover if you just look!
dan__wright
posted on 2/9/10 at 08:46 AM |
yeah its the pro, was easy to fit as i was in the middle of re-doing my ecu loom (but pretty easy anyway).
the worst part was the vac takeoff on the throttle bodies, there's an existing take of on each one (used for balancing) but the hole in the end
is about .5mm, had to be drilled out to 2.5mm, especially when the drillbit got stuck!
40inches
posted on 2/9/10 at 10:42 AM |
Looked at this myself, a couple of questions:
How does it cope with part throttle changes, say,1/3-1/2 throttle?
Is it really worth almost £700 for road use?![](/images//smilies/shocked.gif)
dan__wright
posted on 2/9/10 at 10:47 AM |
i only did a quick 5 - 10 min test run as there's a few other bits i wanted to sort before i went too fast (and it was first drive after totally
rewiring car including ecu stuff - didnt want to break down too far from home)
it seems to work well at any throttle. steady speed / throttle and it went fine (very smooth change!), fine at WOT and fine on some gentle
acceleration.
the throttle blip takes some getting used to.
im not sure its worth that much for road use but probably is when it comes to track use - i didnt pay anything near that though
eddie99
posted on 2/9/10 at 10:49 AM |
I found a website for £495 inc delivery and vat.... Wonder whether they come up on the bay...
bob tatt
posted on 2/9/10 at 02:41 PM |
which web site was that then ....
eddie99
posted on 2/9/10 at 03:31 PM |
I cant find it anywhere now, URGGG, i'll keep searching..
Might have been:
http://www.motorsport-sales.com/index.php?main_page=product_info&cPath=321&products_id=1588&zenid=38ed1702297a96654baef9f515289705
Nahh it wasn't, it said inc post and vat
[Edited on 2/9/10 by eddie99]
dan__wright
posted on 2/9/10 at 03:48 PM |
thats the max which is something all together different (electronic gear change, eg electric paddles or button gear change)
and doesnt do the flat shift / throttle blip, it can be used in addition to the trickshifter.
[Edited on 2/9/10 by dan__wright]
eddie99
posted on 2/9/10 at 04:36 PM |
What one is yours?
dan__wright
posted on 2/9/10 at 08:45 PM |
the pro (yes i know i said pro above, got confused myself!)
