Kev99
posted on 29/10/11 at 04:02 PM |
R1 08 Heavy crank case breathing
Hi all
Just Done my first track day today (RAFCottesmore) with the new engine 08 R1 4C8
Had a problem with the engine breathing a lot (losing) oil out the crankcase breather
Have got a baffle plate fitted and the Rocker cover mods done
I wasn't running with R888 etc which I wish to next year which will increase the cornering load etc
Any Ideas how to stop this from losing oil
Kev................
adithorp
posted on 29/10/11 at 05:39 PM |
So you've got a breather off the cam cover AIS valve boxes and T'd into the crank breather then into a catch tank/bottle?
If there's still oil going to the tank then how far vertically does the gearbox/crank breather go before the T and then to the bottle? If
there's not a lot of height then oil could still go up it and drain to the tank. Mine goes as high as the top TB's before the T. I also
put gauze in the breathers boxes (ex AIS valves) on the cam cover and the pipe of the gearbox (just folded and rolled up expanded ally mesh) to
restrict the flow of oil should there be any but still allow it to breath.
Mine's 06 but the same should apply. I get nothing in my catch bottle except some condensation if doing short runs. It's completely empty
after a track day.
http://jpsc.org.uk/forum/
Kev99
posted on 29/10/11 at 06:04 PM |
no its just a breather atm will do this and see if that solves the problem
Ive never had a problem on the Road with it but it was the first track day its done
Thanks for the reply
Kev............
kjouk
posted on 31/10/11 at 11:13 AM |
Keep an eye on oil temps as well. When I had this problem it was typically on last session of trackday when pushing the hardest. Fitting a small catch
tank above the crank breather and a oil cooler sorted things.
Edit: See pics in my Photo Archive
[Edited on 31/10/11 by kjouk]
jimgiblett
posted on 31/10/11 at 11:18 AM |
Also dependant on the oil used. When using Redline my old R1 used to mist oil loads but when I swapped to Castrol no probs at all.
- Jim
