Author: Subject: modelling foamy stuff
A1
posted on 21/11/11 at 09:16 PM Reply With Quote
anyone know where to get the foam stuff and the plaster that folk use when theyre designing bodywork?
Talon Motorsport
posted on 21/11/11 at 09:51 PM Reply With Quote
http://www.antenocitisworkshop.com/news/2010/11/blue-foam-pink-foam-foamboard-and-styrofoam/
Bigheppy
posted on 21/11/11 at 10:07 PM Reply With Quote
kingspan celotex from builders merchants
clairetoo
posted on 21/11/11 at 10:15 PM Reply With Quote
I use this stuff - unlike the builders foam it can be fibreglass'd and filled .
Its cuz I is blond , innit
Claire xx
Will weld for food......
Bigheppy
posted on 22/11/11 at 05:50 PM Reply With Quote
the kingspan/celotex is also polyurethane based so can be fiberglassed and filled.
Fred W B
posted on 22/11/11 at 05:56 PM Reply With Quote
If you have any companies nearby that deal with refridgeration/insulated vans or similar they may be able to supply you with polyurethane insulation, or put you onto a supplier. You can also "blow" your own, in usefull shapes if you can get the raw materials to mix.
The foam is classified by density, I used a 32 kg per cubic metre density, heavier would be better.
Fred W B
