joni
posted on 10/12/11 at 05:50 PM |
hiss system
hi dose any of you guys no of anyone thats works at the ecu units on a 929 fireblade to remove the hiss system so you can run without
it............... many thanks jonny
Dangle_kt
posted on 10/12/11 at 05:58 PM |
I believe the US ecu doesnt use the system
Andy B
posted on 10/12/11 at 06:02 PM |
American ecu
does not have hiss security but there are a couple of pin position changes to make if you use it with UK loom. Alternatively motomatrix will match a
key to your ecu for you if you send them the ecu.
Regards
posted on 10/12/11 at 06:03 PM |
Watch this for an idea of what you need. I don't know any way to fool the ecu if you
don't have the key and transponder.
jase380
posted on 10/12/11 at 07:17 PM |
Try Malc at yorkshire engines, he will probably be able to supply the bits required
joni
posted on 10/12/11 at 09:07 PM |
hiss system
i no of a fella in england removes the hiss ...but at a premium its about £300+vat what is deff not lowcost ...............
