l0rd
posted on 22/12/11 at 04:58 PM |
Alloy exhaust vs SS
What do you lot think?
Off you go
myke pocock
posted on 22/12/11 at 05:20 PM |
Alloy exhaust? Can you get them? Never heard of them before but prepared to be edicated.
blakep82
posted on 22/12/11 at 05:25 PM |
hmm, never heard of an alloy exhaust either,can't think why it wouldn't work... sounds an interesting idea
________________________
Confused but excited.
posted on 22/12/11 at 05:38 PM |
I take it you are referring to aluminium alloy? If so why? IMHO it wouldn't last very long.
SS by preference on cost. Monel if you win the lottery.
l0rd
posted on 22/12/11 at 05:56 PM |
Yes aluminium alloy.
Why wouldn't it last very long?
Costly but light.
mark chandler
posted on 22/12/11 at 06:05 PM |
I think the acids will hole it pretty quickly, I know you cannot use copper as it will produce poisonous gases !
MakeEverything
posted on 22/12/11 at 06:17 PM |
Depending on what grade, but I suspect a lot of oxidisation and also a lower melting point than steel?
Kindest Regards,
Richard.
indykid
posted on 22/12/11 at 06:22 PM |
I'm not sure which alloy you're proposing, but most melt at about 650°C.
A puddle below where your exhaust should be doesn't sound good to me
l0rd
posted on 22/12/11 at 06:37 PM |
I have been reading different forums and there are a lot of people who don't have problems running them
Volvorsport
posted on 22/12/11 at 06:49 PM |
drag racers use them to good effect , but obviously not right at the manifold , it would be ok for silencers .
www.dbsmotorsport.co.uk
getting dirty under a bus
gingerprince
posted on 22/12/11 at 06:56 PM |
Neither - mild steel. Absorbs the noise better than SS so works better as a silencer, which is what its supposed to do.
l0rd
posted on 22/12/11 at 07:14 PM |
most of them are back from the manifold. One even claimed that he used one for a turbo downpipe and back
Grimsdale
posted on 22/12/11 at 07:40 PM |
is it possible? sure. would it last? No.
Creep and oxidation would be the main two worries, especially as the exhaust gas has to be approaching the melting point of the material.
posted on 22/12/11 at 08:22 PM |
Drag racing is a totally different ball game. The exhausts would only have to last a one/couple of runs. Top AA Fuel rails have million dollar engines
and they don't last long. They are looking to shave a thousandth of a second off a run time, so look to save a gram in weight, antway they can.
A bit like, if a F1 engine lasts two races, it's been over-engineered.
jimmyjoebob
posted on 22/12/11 at 08:34 PM |
You can use aluminium exhaust manifolds, even before turbos, but only if they are water cooled. Marine engines use them, especially those on jet skis.
Aluminium cylinder heads can cope with the exhaust port temperatures only because of the cooling passages within (or around if air cooled).
In fact, in boats the water cooled exhaust manifolds can pass the exhaust gases into silicon hosing after a very short distance because the water
cooling is so efficient.
[Edited on 22/12/11 by jimmyjoebob]
If at first you don't succeed, hide all evidence you ever tried!
Chippy
posted on 22/12/11 at 11:06 PM |
No evidence that its correct, but have heard that a silencer made from alloy tube is quieter than one made of stainless. Problem seems, to me at
least, finding alloy tube big enough. Cheers Ray
TAZZMAXX
posted on 22/12/11 at 11:33 PM |
Hope this link works. It's for a drag car that a guy called Robbie Ward is building in New Zealand. The engine is a twin turbo Nissan V8 and has
aluminium exhausts (Post #28)
http://www.gtr.co.uk/forum/151739-6s-200mph-pump-gas-nissan-thats-goal-2.html
welderman
posted on 22/12/11 at 11:51 PM |
I made a huge alloy exhaust. Passed SVA at the time. Was quiet and light. But the 90 deg bend on the outlet was changed twice. Until I made a huge
stainless one.
So I would go stainless.
Thank's, Joe
I don't stalk people
Canada EH!
posted on 23/12/11 at 12:22 AM |
Neighbour had a 289 Ford in a Donzi boat, cast ali exhaust manifolds. Even with water cooling the exhaust ate through them in a few years.
posted on 23/12/11 at 09:39 AM |
They have to last at least 2 races!
posted on 23/12/11 at 09:45 AM |
Which part of the exhaust is made from alloy? Definitely not the manifolds, they are steel.
TAZZMAXX
posted on 23/12/11 at 10:08 AM |
The turbo outlets are aluminium
posted on 23/12/11 at 11:24 AM |
I was quoting a Williams Team design engineer, because I know FA about F1. Don't shoot the messenger.![](/images//smilies/tongue.gif)
[Edited on 23/12/11 by Confused but excited.]
