Author: Subject: Rear Diffuser Fittng
johnny chimpo
posted on 24/8/12 at 07:46 PM Reply With Quote
Hi all just received my mnr rear diffuser today and hoping to get it fitted over the weekend. Can any advise on how they fitted there's?
I know the metal strip rivets to the underside of the car to allow to the diffuser to fit into but whats the best way to hold the other edge up. Needs to be strong enough to hold it firmly in place but at the same time be easy to remove for maintenance etc.
If anyone has pics of how they fitted there's that would also be good.
Cheers.
Rob3
posted on 25/8/12 at 08:39 AM Reply With Quote
Inside the wheel arch, just about 2" in just above the chassis rail. I put one M6 rivnut on each side. Big washer under the bolt head and it holds it lovely. Don't even need to jack it up to remove or fit.
Rob
johnny chimpo
posted on 27/8/12 at 09:58 PM Reply With Quote
Going to sound daft here but I've no experience of rivnuts.
Did you fit the rivnut through the chassis or only through the fibreglass side panel of the car? If through the side panel how do you stop the rivnut from turning when trying to fit the bolt into it, or do they bite Into it to prevent turning.
Just no experience of rivnuts and no places in my local town seem to stock them.
Rob3
posted on 27/8/12 at 10:09 PM Reply With Quote
I put the riv nuts in the fibreglass panel rather than the chassis tube. Due to the downwards loading the fibreglass is adequately strong enough. The ones I used are splined and pull them selves up as the name suggests - like a rivet. I had similar supply issues - a company called make ends meet do the best tool I've found and also supply the inserts.
http://www.memfast.co.uk/
Rob
johnny chimpo
posted on 27/8/12 at 10:56 PM Reply With Quote
Cheers Rob, actually been looking at that site but wasn't sure what ones to go for
Which tool did you get?
blakep82
posted on 27/8/12 at 11:18 PM Reply With Quote
did you try kip marina mate? never looked for them myself, but wouldn't really been surprised if they sold them
________________________
johnny chimpo
posted on 28/8/12 at 05:12 AM Reply With Quote
Good shout Blake!
I'll give them a try after work tomorrow
sdh2903
posted on 28/8/12 at 08:38 AM Reply With Quote
Hi mate
If you dont want to buy a tool you can have a lend of mine, I've got a load of m6 rivnuts spare aswell.
Just drop me a u2u if your interested.
cheers
johnny chimpo
posted on 28/8/12 at 08:29 PM Reply With Quote
u2u'd! ;-)
johnny chimpo
posted on 2/9/12 at 07:31 PM Reply With Quote
Now got this fitted, at the expense of a pair of rear arches :-(
I've fitted it as suggested with with 1 m6 rivnut on each side as far back as I can go before hitting the chassis tube. The fit is ok, but the diffuser seems to sag a little in the middle leaving a small gap. Anyone else had this issue and if so how did you resolve it?
I'll post up a wee pic of how it's looking so far.
johnny chimpo
posted on 2/9/12 at 08:09 PM Reply With Quote
