franky
posted on 31/12/12 at 10:33 AM |
zzr1100 parts
As above, has anyone got any zzr1100 parts knocking around?
maccmike
posted on 31/12/12 at 10:49 AM |
like what?
franky
posted on 31/12/12 at 10:50 AM |
Cams/carbs/broken engine?
russbost
posted on 31/12/12 at 11:00 AM |
I have a set of ZZR1100 carbs I want £30 for if of any interest - really good condition, but missing one idle screw from one carb IIRC
minitici
posted on 31/12/12 at 11:17 AM |
Got a head and cams - only two slightly bent valves.
franky
posted on 31/12/12 at 11:30 AM |
Russ do you know which model they're off?
minitici
posted on 31/12/12 at 12:04 PM |
Not sure if it was a "C" or "D" model.
The head and cams came from a big bore (1160cc) from a racing sidecar.
Unfortunately the no4 piston's little end failed and the piston stuck at TDC and hit the valves.
No.4's valves are bent but the head looks OK.
Head looks like it has had a little porting work done, not sure if cams are standard.
russbost
posted on 31/12/12 at 12:37 PM |
No, certainly not for sure, do you know of any identifying features?
franky
posted on 31/12/12 at 04:50 PM |
Not 100% sure at the min, i'll get back to you.
Thanks again.
chrisni1986
posted on 8/7/13 at 06:38 PM |
fully built complete missile of an engine of any interest to you? lol
jossey
posted on 8/7/13 at 06:44 PM |
Had loads a month ago but sold an engine n loads of bits for £200
Sorry.
David Johnson
Minicooper
posted on 8/7/13 at 06:46 PM |
I have a ZZR1100 D3 engine, it's just sat in the garage for years, I believe it to be in perfect working order but I can't guarantee it,
as it has sat around for so long. It's had oil squirted down the bores, all holes sealed and occasionally turn it over
£250 if you are interested, I also have everything else for sale to make it run
