Author: Subject: Clutch quadrant
Sierra
posted on 10/2/13 at 01:27 AM Reply With Quote
Clutch quadrant
I'm after a black ford Sierra clutch quadrant as I've modified the pedal box for more leg and now the clutch hits the bulkhead when pressed. I've currently got the yellow one
Mark Allanson
posted on 10/2/13 at 08:36 AM Reply With Quote
Available in all good motor factors for peanuts
dave r
posted on 10/2/13 at 09:00 AM Reply With Quote
or you can put an alloy spacer on the top of the yellow one so the cable rides on top instead of in
even cheaper than the motor factors
I'd love to give my imaginary friend a great big hug,
but this jacket makes it impossible.
Sierra
posted on 10/2/13 at 11:53 AM Reply With Quote
How and where would I put the spacer? Have you got any pictures.
I've checked a few sites but they don't seem to have the black quadrant for a Sierra only other fords like escort/fiesta/transit.
evo97
posted on 10/2/13 at 01:15 PM Reply With Quote
Think I have one if still required
Sierra
posted on 10/2/13 at 01:22 PM Reply With Quote
Yes please, can you confirm what size it is.
I've got a bit confused when searching as I've read the black is the largest at 55mm therefore shorter pedal travel but when I look around there's some white ones that say 55mm.
Also the one I have at the moment is a semi circle so it sits on a stop plate to stop the pedal coming forward but some quadrants are a quarter of a circle so the stop plate wont be in the right place
dave r
posted on 10/2/13 at 02:13 PM Reply With Quote
u2u sent
evo97
posted on 11/2/13 at 01:06 PM Reply With Quote
Sierra
posted on 11/2/13 at 08:23 PM Reply With Quote
Many thanks. Ill give mine a measure when I go to the garage. Can anyone confirm if this is the one that requires less pedal movement for more cable pull?
How much are you after for it delivered?
evo97
posted on 11/2/13 at 08:36 PM Reply With Quote
How does a fiver sound?
Sierra
posted on 11/2/13 at 09:12 PM Reply With Quote
Sounds good to me, thanks.
