BigDawgV8
posted on 9/3/13 at 09:58 PM |
Narrowing a Toyota Live Axle - Anyone Done It?
Hi All,
Need a little advice.
I have a Toyota Celica axle that needs narrowing.
A long shot I know but has anyone narrowed one of these? Is it even possible?
Might have to look at fitting another axle (cheaper option). Need a wheel to wheel width of 50 inches or so.
Thanks for looking!
Canada EH!
posted on 10/3/13 at 12:05 AM |
It is regularly done for drag racing but not cheap the outer axle is cut and the extra cut out and welded back together.
The axle shaft is then shortened and a new spline is cut on the axle shaft. The next problem is the differential is not centred.
Bare
posted on 10/3/13 at 04:29 AM |
Erm.. isn't the Celica axle a surprisingly Heavy/ klunky thing?
As in why would onechoose ..it.., let alone spend large to alter it to fit ?
Jed
posted on 10/3/13 at 09:33 AM |
Depending on where you're measuring it, but iirc 50" sounds close to the width of a Ford 105e (Anglia) axle. That's if you can find
any..
BigDawgV8
posted on 10/3/13 at 10:03 AM |
Thanks all,
I've had the axle for years. It's currently in a Morris Pick-up but it just too wide.
Nice strong axle can handle 300-350 bhp no problem.
Cost of narrowing etc. is just too much to justify so I will have to source another.
Jag, Sierra or Ford live are all options, just have to get the tape measure out!
Thanks!
daniel mason
posted on 10/3/13 at 10:08 AM |
am sure the legend race cars run a toyota rear axle. could be a starting point!
