2.0 Sporty Spec Pinto With Twin 40s, Newman Cam And Pulley, Clutch, Alternator, Filters etc. etc
Hi All,
Removed from my newly purchased Super Cat to make way for Mazda power. This is totally complete and I believe everything required is here to go
straight into a similar kit.
The engine was built less than 2500 miles ago by Maynard LTD (invoice included) and features:
- Ported and polished cylinder head
- Newman Rally/Sprint Cam
- Newman Adjustable Cam Pulley
- Twin 40 Webers
- Westfield DCOE Inlet Manifold
- Magnecor leads and Bosch coil
- Various new gaskets, internal components etc. etc.
- Lightweight steel flywheel
- Heavy Duty uprated single plate clutch.
Also included with the engine is:
- Alternator with mount
- Stainless steel exhaust manifold pipes (to suit Tiger and similar) which are heat wrapped, collector not included I'm afraid.
- Piper X Air Filters
- Weber throttle linkage
- Two engine mounts
- Various minor plumbing/install bits which have not been removed
- QH Starter Motor.
The engine and associated components are extremely clean and ready to go straight into use and included are approx £2200 of invoices for components
fitted to the engine/build of the engine.
I drove the car 170 miles with this engine and it was perfect with good oil pressure and no overheating.
It is available for collection now. Closest offer to £1200 takes the lot.
