Author: Subject: Can someone turn me some spacers please
big-vee-twin
posted on 12/5/13 at 11:29 AM Reply With Quote
Hi All,
I need some spacers turning, so I can fit my Wilwood calipers to the disc diameter please.
I require 4No - 22mm diameter x 9mm deep with a hole through the centre to suit a 10mm bolt.
Can be aluminium but steel ok too.
If you can help me please u2u me a cost many thank you's.
http://www.triangleltd.com
trextr7monkey
posted on 12/5/13 at 04:32 PM Reply With Quote
If thereks no one local. OfferingI can get one of the lads to do them tomorrow.
Just send me a message if you aren't fixed up by then
Atb
Mike
big-vee-twin
posted on 12/5/13 at 05:45 PM Reply With Quote
HowardB has offered to make some up if he has the raw material in his garage.
I will contact you if he cannot do them for me.
Many thanks
trextr7monkey
posted on 12/5/13 at 06:32 PM Reply With Quote
Fine no worries
Atb
Mike
Matt @ TDF
posted on 12/5/13 at 08:46 PM Reply With Quote
Flowjet is usually way easier and much cheaper for things like thin spacers etc.
We use H2O Profiling for lots of our stuff, chaps name is Thom and he is very good. If you tell him I sent you I'm sure he'll make sure your sorted. http://www.h2oprofiling.co.uk/
