shutty34
posted on 30/5/13 at 12:02 PM |
Pinto sump
How much do you need to trim off a 2.0 pinto 205 sump is there any plans or info on this
Regards
Daz
Aaron_n_Sim
posted on 30/5/13 at 12:13 PM |
Hi
Its approx 150mm from mating to cutoff point, fit the engine & gearbox & cut the sump so its level with lowest point of the gearbox,
that's basically what the Haynes book advice is!
HTH
Work to Live don't Live to Work
mcerd1
posted on 30/5/13 at 12:49 PM |
level with the lowest point of the bellhousing is about the best you can do.... thats what my dax one is
a bit like this one: http://www.joeybrown.co.uk/pages4/sumps.html
but some folk add extra capacity towards the back (like the westfield alloy one) rather than out the side, I've never heard any conclusive proof
as to which is better.....
jps
posted on 30/5/13 at 02:12 PM |
Are all Pinto blocks and sumps the same? I have a 1.6 pinto which will need a sump trim at some point - just wondering if a JoeyBrown one would fit
OK...
Aaron_n_Sim
posted on 30/5/13 at 02:19 PM |
OK...
I've had both sized engines the blocks and sumps are the same if I remember correctly.
I'll soon be selling a 2.0l with a standard head, and a ported and polished head with full kent fr32 kit, vernier pulley etc! plus lots of other
pinto related bits.
Aaron
jps
posted on 30/5/13 at 02:27 PM |
OK...
pinto related bits.
Aaron
pm me when that happens!
Aaron_n_Sim
posted on 30/5/13 at 02:33 PM |
OK...
pinto related bits.
Aaron
no probs, you can u2u me if you want a full list! theres 32/36 dgav weber carb, new bottom & top end gasket sets, i'll have to haul it all
out!!!
Aaron
jacko
posted on 30/5/13 at 03:43 PM |
reduce the sump by 40mm that brings it level with the bottom of the bell housing
do the same with the pick up pipe
jacko
