T66
posted on 24/8/13 at 07:02 PM |
Twin radiator ducting required?
I probably know the answer to this one, the rads could do with a bit of alloy sheet either side to promote air flow ?
tomgregory2000
posted on 24/8/13 at 07:22 PM |
Just remember that air WILL take the path of least resistance
So the air will just go round your rads, not through
T66
posted on 24/8/13 at 07:26 PM |
The path of least resistance is not ducting it, but I knew I had too - cheers Tom
bi22le
posted on 24/8/13 at 08:57 PM |
Where on your car is it and what is it a rad for?
Could you not just angle it up and block either side?
Why are you against channelling air in? Asthrics could be improved with some sensible grilling.
Please read my ring story:
T66
posted on 24/8/13 at 09:48 PM |
Bottom radiator in the grill is the chargecooler, the one second in the airflow is the engine radiator.
Blocking either side of the 2 support sections infront of the rad shouldnt be too bad, and probably the simplest option. Its going to get a full width
mesh grill, so some thought is needed on how I want it cosmetically as well as functionally to keep the grill looking right.
Something like this
bi22le
posted on 24/8/13 at 09:56 PM |
Not enough space to get them side by side with good flow through both then?
Loving your build by the way.
T66
posted on 25/8/13 at 05:29 PM |
I did intend going side by side, then read a bit about chargecooler rads and decided on bigger is better. So the width is good, but not wide enough
for 2 radiators, hence the piggy back affair....
My new shift pattern is making building my car a bit of a scarcity, however now the weather is cooling down slightly garage fun will return.
Thank you for the encouragement - i need it...
