Gear Monkey
posted on 21/5/14 at 06:58 AM |
Slipper Clutch
The scratch build zx9r powered beast is coming along a treat and I'm starting to think about ways to ensure it drives just the way I want it. As
a biker I understand the benefits of a slipper when pushing hard and think one would be a great addition to the car especially on the track, however
from a fair amount of googling it looks like there isn't a direct aftermarket clutch for my engine (2004 model). Do any of you guys have any
experience with this??
Many thanks
Paul
dave_424
posted on 21/5/14 at 09:06 AM |
I thought that production of the ZX9 ended in 2003 so not sure if you are correct in thinking you have a 2004 model.
I do know that some people who have messed around with lockup clutches on the zx9 have trouble with breaking off the clutch puller but in the end they
managed to get it working.
I have a turbo zx9 and will be adding more boost very shortly. I have barnett heavy duty clutch springs and that has held at 180bhp but if I start to
get clutch slip I will look at stiffer springs or make my own lockup clutch.
Dave
aka Keith
posted on 21/5/14 at 10:22 AM |
Paul,
I have looked into this in the past, and similarily have not ben able to find a direct slipper clutch replacement. I use my ZX9r BEC on the track and
road and have not found the standard clutch an issue when pushing on at all.
I did read that the zx7r clutch can be modded to slip more http://homepage.ntlworld.com/webzxr/zxr750r/Features/slipperclutch.html
and that the 7 and 9 use the same clutch basket, so I expect that you could do the same for you zx9r clutch. but as I said having done many miles at
pace, and a number of trackdays, I have never found the stock set up to be an issue.
hope that helps
cheers
Craig
Gear Monkey
posted on 25/5/14 at 07:35 PM |
Thanks Guys, That's put my mind at rest
Paul
