hamza
posted on 20/10/14 at 06:08 PM |
110 amps mig welder for chasis
Can I use a 110 amp mig welder for welding the locost frame
Regards
Hamza
Slimy38
posted on 20/10/14 at 06:12 PM |
Yes.
I use a 150 amp mig on setting 2 out of 6. I take it up to 4 to weld the plate, but that's still (roughly) 100 amps.
Andy S
posted on 20/10/14 at 06:14 PM |
If you were a competent enough welder to fabricate a chassis you would not have to ask that question
hamza
posted on 20/10/14 at 06:19 PM |
Yes Andy
I am not a competent welder that is why I am asking such questions- where I live it costs a fortune to buy a mig welder so will be needing a lot of
assistance![](/images//smilies/sad.gif)
43655
posted on 20/10/14 at 06:25 PM |
yes, as long as it's a decent welder (so will actually be producing that ind of power you use)
with regards to competence and amperege, I too just work on 4 out of 6 on a 150amp Cebora.
this might be around 100amp, I don't know, it's done by feel, and you're welcome to see the MIG welds I've done so far.
Hamza, why, whereabouts are you?
hamza
posted on 20/10/14 at 06:32 PM |
I am stranded in a place called Peshawar, on the Pakistan side near the Afghan border- quite a challenge to survive
Slimy38
posted on 20/10/14 at 07:13 PM |
Well, at least you won't have to worry about the IVA when you've finished building it... ![](/images//smilies/smile.gif)
mark chandler
posted on 20/10/14 at 07:20 PM |
Depends on the quality of the welder, use 0.6mm wire and you should be okay.
Cheap welders are generally improved by replacing the earth lead and clamp with something more substantial.
Try on a piece of 2mm steel before you buy
theprisioner
posted on 20/10/14 at 07:28 PM |
Well Hamza I am most impressed why not do what some on this forum do and post examples of your welding for constructive comment. I hope you are doing
a blog of your project as I for one would be fascinated. I wish I could be of more help best of luck.
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
posted on 20/10/14 at 08:15 PM |
Yes Andy
assistance
Hi Hamza,
Ask all the questions you want to, there is a lot of help available on here.
I welded up a go-kart frame from 25mm x 3mm wall thickness steel with a 110A MIG on full power. I then made a welding trollet from 25mm x 1.5mm wall
thickness steel (as you would use for a Locost). Much easier and only needed the power on 3 of 4 settings.
You might also want to sign up on the MIG welding forum for more help -
http://www.mig-welding.co.uk/forum/
Best of luck with your project and keep us updated with your progress.
wylliezx9r
posted on 20/10/14 at 09:16 PM |
Very constructive and welcoming.
George Best
blakep82
posted on 20/10/14 at 10:52 PM |
Andy s must've been born welding torch in hand!
________________________
NigeEss
posted on 20/10/14 at 11:47 PM |
You must be the first builder from that part of the world !!
As mentioned, sample pics to help us give tips. Loads of welding tutorials online and join Mig Welding
Forum as they, like the majority of people on here are also
very helpful.
I'm self taught, loads of practice and with a little help from Youtube, my welding has been complimented by a few MOT testers
hamza
posted on 22/10/14 at 06:05 PM |
Dear All,
Thanks a lot for all your assistance- will be keeping you updated- hopefully will be getting my mig welder on the 13th of November, will be posting
the picture of my welding machine and first weld
Hamza
