WesBrooks
posted on 17/12/15 at 11:31 AM |
Autobox and start inhibit for all other than N / P?
Afternoon all.
Why do they let you start a manual in gear, but not an auto? While off road I was tought it is acceptable to start in low ratio while in gear without
clutch down. This isn't possible in an auto with standard wiring. I also like the idea of an emergency get yourself off the road with the
starter motor.
Are there parts of the MOT or IVA that dropping this requirement would have? Perhaps I could achieve this by having the interlock wired as per-usual
but with a push button defeat to use in emergency?
WesBrooks
posted on 17/12/15 at 12:33 PM |
Ok. Checked the M1 test manual and couldn't find any requirements for a start inhibit device.
Question remains is there any reason why some cars permit start in gear on a manual but not an automatic? Perhaps I shoudl re-post in the
engine/transimission section?
sprintB+
posted on 17/12/15 at 12:38 PM |
I dont think you'll ever get a starter motor to spin enough to engage an auto box, I may try it on my Saab. No I wont it wont let me. Doh !!
posted on 17/12/15 at 12:43 PM |
I've used a starter motor to move a Pug 205 before, easy enough and easier than pushing it too.
Maybe auto-boxes have electronics that prevent you doing so?
Sam_68
posted on 17/12/15 at 12:55 PM |
As far as I'm aware, the only reason is as a safety feature; on account of the fact that a torque converter automatic would happily fire
in gear and then creep forward at a pace that might not attract attetion, whereas you need to make a really determined effort to start a manual box in
gear, and really couldn't do it inadvertently.
As sprintB+ suggests, you almost certainly won't get enough torque from the starter motor to move the car forward, once you've allowed for
the slip in the torque converter, so it would be a pretty pointless exercise, anyway - you'd have to get the engine to fire before you got any
forward motion.
FuryRebuild
posted on 17/12/15 at 12:58 PM |
Your starter motor is designed to provide the given torque for a very short period of time, and even for this period of time it has to draw current
down some pretty thick cables. Think of the extra load if it had to drag a car around at the same time - your battery wouldn't last and the
cabling etc. would get dangerously hot.
Furthermore, for every time you use your 'emergency pull you along' feature, you'd probably put it through a wall more often.
I think the interlocks are there more so because they were easier to do with an auto, and with the torque converter continuously engaged,
there's no option to disengage the drive between the engine and box - you need the box to be in neutral.
Quite a few manual cars now won't let you start unless the clutch is down. I only drive autos on the road myself, so wouldn't know much of
this thing called "clutches"
www.furyrebuild.co.uk
WesBrooks
posted on 17/12/15 at 12:59 PM |
quote: Originally posted by sprintB+
I dont think you'll ever get a starter motor to spin enough to engage an auto box...
Keep forgetting how slow they are. You might be on the money there. 120rpm for the starter, usual idle speed is around 750ish.
FuryRebuild
posted on 17/12/15 at 01:01 PM |
good point - my point above presupposes the starter motor can do that, and I think the torque converter slip means I may be wrong there. I know
admitting one may be wrong is a crime on the internet, but there you go.
ken555
posted on 17/12/15 at 01:04 PM |
The pool cars at work, need the HandBrake on, in neutral & Clutch pushed, before the starter does anything.
Great fun watching the look on peoples faces until they remember.
WesBrooks
posted on 17/12/15 at 01:07 PM |
often.
My 2009 Skoda will let me start in gear. Oddly the hire car in Germany which was nearly the same but estate didn't let me do so. I
wouldn't avoid doing it for that small risk of mistake and I think the push button interlock defeat for 'are you sure' would remove
that concern.
As for the wiring thats not a problem as I'd be sizing it appropriately for the starter and fusing it.
...but as others say it's a bit pointless if the torque converter is well below stall speed. It'll be an extra drag for no gain.
Thanks all!
posted on 17/12/15 at 01:08 PM |
On some US market manual transmission cars the starter cannot energise without depressing the clutch.
A lot of classic cars are very reluctant start due to the extra friction with the clutch depressed even if out of gear.
[Edited on 17/12/15 by britishtrident]
WesBrooks
posted on 17/12/15 at 01:10 PM |
The pains of random hire cars. Sat in an auto recently and had a real brain fart. 'Where's the effin hand brake?!!' Then
'Wahaa! Who's knicked me gear knob!?!!!'
WesBrooks
posted on 17/12/15 at 01:11 PM |
My old '74 beetle would roll along nicely on the starter which got me out of a couple of awkward situations!
posted on 17/12/15 at 01:34 PM |
True - my 57 plate Passat will only start with the clutch depressed so effectively out of gear.
SteveWalker
posted on 17/12/15 at 01:56 PM |
Bet that's handy when someone stalls in the middle of a junction and needs to start it quick and get out of the way!
SteveWalker
posted on 17/12/15 at 02:02 PM |
I don't like that idea. I've certainly used the starter to "drive" out of a carwash when the HT system got wet and the car
wouldn't start. Without it I'd have had to push it out from the driver's door, squeezing past and under the wet and dripping
brushes.
Many cars these days are too heavy to push (especially for women or the elderly) and using the starter is a good way to get them out of the way and to
safety if you break down in an awkward spot.
WesBrooks
posted on 17/12/15 at 02:03 PM |
Good point that. I've stalled many times while pulling away and a quick dip of the clutch and spin of the starter can often be done quick enough
to save too much embarassment! Requiring the hand brake to be up is mad.
Can't see how I would stall it while pulling away (although it did stall while idling before strip down due to dodgy air valve) but a just in
case defeat would save from rushing the selector into N to restart, missing and getting R or P!
mark chandler
posted on 17/12/15 at 10:13 PM |
It's a safety issue with auto's, in gear they will start easily as no load, the engine picks up and the car starts to moves.
Manual car it's a lot less lightly to happen due to the load, you also get a very positive indication as the car jerks forward.
posted on 23/12/15 at 09:03 AM |
Indeed, most cars are too heavy to push on your own these days - particularly if you want to steer and brake as well.
TBH a 205 is that light weight it's not hard to push, but the task of stopping it once it's moving is harder!
WesBrooks
posted on 5/1/16 at 03:58 PM |
Reminds me of a track taster day at Manchester Velodrome many moons ago on the fixed gear bikes. While you fully appreciate how hard it is to get a
bike moving in a high gear you get a new found appreciation for the amount of work bike brakes do when you try to stop after a lap sprint! Sprint from
my perspective that is, not sprint from the perspective of others riding on those boards!
