locoboy
posted on 6/12/16 at 01:36 PM |
what grade wet and try to use to polish aluminium
I want to remove the milling marks from the face of some aluminium pistons (they won't be used as pistons again)
What grit of wet and dry should i be starting with and then finishing with prior o polishing?
Locoboy
loggyboy
posted on 6/12/16 at 01:42 PM |
If there are no major scores/scratches then 1200/2000 should be fine, then a cutting compound like G3/4 or tcut.
Mistral Motorsport
locoboy
posted on 6/12/16 at 08:49 PM |
Cheers :-)
Locoboy
