designer
posted on 9/1/24 at 10:01 AM |
13in x 3in rims
Anybody know where I can get 13in x 3in alloy rims.
posted on 9/1/24 at 03:34 PM |
3" width has got to be motorcycle type size?
13" diameter seems too small for a motorcycle though (moped perhaps).
Do they need to be single side attaching like car wheels (not double side like many motorcycles)?
designer
posted on 9/1/24 at 04:20 PM |
Yep, for maxi scooter tyres.
Chasing a single sided mounting, like a car, as I don't want to support the Scooter wheels spindle of 11mm on both sides with a loop. Ugly!!
posted on 9/1/24 at 04:38 PM |
I understand the desire for single sided mounting. When I built a sopbax cart I used 26" MTB front wheels for the rear wheels and 24"
wheelchair wheels for the front.
Rear weehls supported both sides, front wheel just one side.
![](https://locostbuilders.co.uk/upload/kart-5.jpg)
designer
posted on 9/1/24 at 05:06 PM |
The spindle on the scooter wheels is 11mm diameter. I could replace the normal bearings with taper roller bearings and use a single castle nut to
locate. But 11mm is a bit too small for an end mounted spindle. Unless I can find a bit id metal strong enough to stand forces generated when doing
50-60 MPH.
Schrodinger
posted on 9/1/24 at 05:41 PM |
In my dim and distant past I rode a Lambretta scooter and IIRC both front and rear wheels were mounted on a single side. No idea what the wheel size
was though.
Keith
Aviemore
padrc66
posted on 11/1/24 at 08:39 AM |
Have you looked at the Piaggio MP3 front wheels - 2 front wheels with single sided mounting and some of them are 13"?
eg
https://www.ebay.co.uk/itm/196136612270?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=CYy4rnTJQ-K&sssrc=2047675&ssuid=v7qJTm
rGQx6&widget_ver=artemis&media=COPY
