adamhay
posted on 17/7/05 at 11:47 PM |
Caterham Hayabusa Turbo
My car's nearing completion now - it's got it's MOT on Friday (fingers crossed...) and it should be out at Loton hillclimb on 30th
July.
Anyway, thanks to everyone who's offered advice over the past 9 months or so.
If anyone's interested, this is a video of it on the dyno:
http://www.filecabi.net/v.php?file=1121074850.wmv
If you're thinking of doing something similar, feel free to ask any questions.
http://www.youtube.com/watch?v=lnp0WDDW7xs
andylancaster3000
posted on 17/7/05 at 11:53 PM |
Wow..looks impresive. Sounds (and looks) rather potent!
yahshuatwo
posted on 18/7/05 at 02:16 AM |
Damn! that's impressive. What turbo and compressor wheel a/r are you using. I'm building a stock Busa 7 replica, however, I'm
considering the turbo option.
adamhay
posted on 18/7/05 at 07:32 AM |
yahshuatwo: Turbo unit is from a Volvo - a V70R I think.
andylancaster3000
posted on 18/7/05 at 08:56 AM |
Your in Camberly aren't you? If so i may have to blag a ride sometime
scoobyis2cool
posted on 18/7/05 at 09:06 AM |
I bet that's gonna shift on the road!
Pete
andylancaster3000
posted on 18/7/05 at 09:08 AM |
Does that use the Hayabusa ECU for the injection or do you have an aftermarket mappable one on there?
adamhay
posted on 18/7/05 at 09:59 AM |
andylancaster3000: It has 8 injectors - the standard 4 on the standard ECU and 4 additional injectors on another ECU.
alfasudsprint
posted on 18/7/05 at 11:07 AM |
Wow! So more than 600/tonne....whats your estimated 0-100mph? Less than 8 seconds?
posted on 18/7/05 at 11:11 AM |
Good luck with the MOT.
Winston Todge
posted on 18/7/05 at 12:29 PM |
Hey Adam,
Very impressive setup! Near enough 300 rwhp should certainly demand some major respect...
How far can you push (in hp terms) the standard fuel injection setup? i.e. Standard 4 injectors and an aftermarket ECU...
Thanks for any help,
Chris
adamhay
posted on 18/7/05 at 01:08 PM |
Winston Todge: The standard injectors are only good upto about 220bhp - that's why I need 4 additional injectors. The setup I have should be
good for 360 crank bhp on 1.5 bar of boost. I'll get used to 240rwhp first (it's adjustable down to this)and then add more boost to see
how it goes.
alfasudsprint: CarTest (simulation software), which is meant to be very accurate, predicts a 2.7sec 0-60mph, 6.6sec 0-100mph, and 10.8 standing
quarter. This is comparable with the real performance of other super fast Caterhams so hopefully I can run a bit quicker and beat them.....my
car's not been designed as a drag car though - the important thing is beating people up hills and along sprints.
yahshuatwo
posted on 18/7/05 at 02:00 PM |
AdamHay: How does this secondary ECU work in tandom with ths stock ECU.? Is there a plug-in part to the loom or do you have to "spilce"
wires to make it work?
adamhay
posted on 18/7/05 at 03:06 PM |
yahshuatwo: The additional ECU uses the stock sensors and is essentially spliced into the loom. I had a new loom professionally made so this
wasn't a problem.
The additional ECU comes with a base map that was pretty much spot on before it was dyno'd - it only needed a little tweeking.
I appreciate that getting someone else to do this is kind of cheating but it would have been a nightmare sorting it out myself and I didn't want
to risk damaging my engine with dodgy fueling/ignition.
carnut
posted on 18/7/05 at 03:44 PM |
If you dont mind me asking, how much do you think it has cost to do the turbo conversion?
Any chance of posting a list of all the main bits needed. I'd like to do something sililar on my blackbird engine.
thanks
Carnut
carnut
posted on 18/7/05 at 05:18 PM |
Cheers, ive seen this before but thought it might be cheeper to source bits myself.
ChrisGamlin
posted on 18/7/05 at 05:22 PM |
LOL, even those prices are a bit optimistic Id say, a friend has done an almost identical install to Adam's in his Westie and he reckons its not
far shy of 5 figures that its cost him, and he did most of the install himself, including some engine upgrades (pistons, rods etc) to handle the extra
power. Some of the money may be attributed to fancy hoses etc, but certainly not £7-8k's worth!
BTW, congratsc Adam, we'll have to go out for a blast sometime, Im only in Lindford (near Bordon). Bazzer should be on the road with his soon
too, he fired it up for the first time this weekend. I suggested the name Terabusa just for a bit of one-upmanship on your Gigabusa effort
[Edited on 18/7/05 by ChrisGamlin]
