Author: Subject: brake problem
madteg
posted on 27/12/06 at 08:52 PM Reply With Quote
brake problem
all four brakes are coming on, when they warm up and staying on, what could be the cause of this. have to let pressure of then they are ok,
ch1ll1
posted on 27/12/06 at 08:57 PM Reply With Quote
whats your brake set up?
single/twim master etc?
where do you release the pressure from?
[Edited on 27/12/06 by ch1ll1]
posted on 27/12/06 at 08:58 PM Reply With Quote
all 4 would imply a master cylinder problem. Is it single or twin? Do you have a spring to ensure that the pedal returns fully?
mike.williams1
posted on 27/12/06 at 08:59 PM Reply With Quote
brakes holding on
i would check the pivot from master cylinder to the pedal i have seen similar fault on a peugeot 106.
robinj66
posted on 27/12/06 at 09:15 PM Reply With Quote
I've just had a similar problem on my Cobra but it only affected the front brakes. If you let out fluid through a bleed nipple the brakes are ok.
Firstly check that you have left enough "space" in your reservoir for the fluid to "expand" once the brakes are hot.
If that is all ok then it's a problem with the master cylinder - had mine out 3-4 times and changed/checked te sealsbut nothing would sort it. I ended up replacing the master cylinder and everything is ok now ( I think the bore was a little scored)
t.j.
posted on 27/12/06 at 09:28 PM Reply With Quote
I would suggest to look if the mastercilinder comes into the orginal rest position. Probably not. So the fuild can't flow back which causes these problems.
Grtz Theo
madteg
posted on 27/12/06 at 10:13 PM Reply With Quote
brakes
thanks will have another go tomorrow.
posted on 28/12/06 at 08:35 AM Reply With Quote
When they lock up, try hooking your toe under the pedal and pulling it back up. If the brakes free off, it supports the "not returning to the ready position" theory suggested earlier.
RazMan
posted on 28/12/06 at 12:39 PM Reply With Quote
Exactly my thoughts - you might need to install a return spring to allow fluid to move around correctly. It might be binding pivot linkages or just need bedding in.
Raz
