Author: Subject: 780W Generator £33 B&Q
jack trolley
posted on 13/1/07 at 04:28 PM Reply With Quote
Clearance item reduced from £50.
COREdevelopments
posted on 13/1/07 at 04:30 PM Reply With Quote
are they any good? wouldnt be able to power a 50litre compressor would it?
posted on 13/1/07 at 04:59 PM Reply With Quote
depends on the hp/kW of the compressor! The answer is unlikely though.
[Edited on 13/1/07 by JoelP]
posted on 13/1/07 at 05:53 PM Reply With Quote
I had to repair one of these for my cousin a while back after he tried to power a toaster with it!
These generators are unbelievably cheap, but they are certainly very cheaply built. They have a mechanical governor so frequency stability is poor and a very crude voltage regulation system so voltage jumps up and down a fair bit when you apply or remove a load. They also have two stroke engines, so fuel economy not great.
However, if you want to power something that is reasonably intolerant to frequency and voltage variations, e.g. lighting or small power tools they are fine.
B&Q were selling a 1KW 4 stroke generator that looked a lot better for £70-80 a while back.
[Edited on 13/1/07 by MikeRJ]
morfy
posted on 13/1/07 at 08:06 PM Reply With Quote
i had to repair my bros 4 stroke geny from b and q as it would not start.
when stipped:
1 the valves looked like they missed out on the hardness that most depend on.
2 the bore had DENTS in it.
3 the piston was missing parts of the crown.
and all this was from a 1 time use for a motor cross event before it was stripped
graememk
posted on 13/1/07 at 09:04 PM Reply With Quote
i have the 2stroke jobbie. . . . .i use it for powering lights during bbq season and a the hedge cutter twice a year. works ok but as said the lights get brighter and duller every now and again
posted on 13/1/07 at 11:07 PM Reply With Quote
You lot not got mains electric?? Its fairly wide spread now in 2007.
I've had for a long time time, theres even 3 phase on the pole outside when i get round to that big CNC
posted on 16/1/07 at 08:48 AM Reply With Quote
Lots of people have lockups with no electricity...
andyps
posted on 16/1/07 at 01:39 PM Reply With Quote
You get what you pay for, but as a basic generator for occassional usage for small power tools they are OK - I have had one for a while and it works alright. Have tended to use it for things like powering an electric cool box when camping, and charging the battery and running the fridge of a motor home when at Le Mans. Have used it with tools of 900W without a problem.
Like many things made in China the same item is availbale with a variety of different branding applied.
[Edited on 16/1/07 by andyps]
