Author: Subject: Been Grafting in the Garage again.
jollygreengiant
posted on 4/2/07 at 05:12 PM Reply With Quote
Well Its been a WONDERFUL week of.
Removed pedal bracket ass. Removed cable clutch pedal and replaced with hydraulic pedal and pivot pin. Refitted pedal ass. Fitted clutch master cylinder and Connected up all cylinder rods, adjusted & locknutted.
Swapped 5 stud rear drive flanges down to 4 stud drive flanges, fitted discs, caliper carriers, pads, calipers & connected flexy hoses at rear.
Adjusted/rebated front of gearbox mounting plate.
Adjusted position of engine, Cut engine mounting plate plates. Cut tube & adjusted to fit between plates.
Cut steering dop link. Found problem. Corrected problem (see earlier post) cut new part, cut extension tube to suit & fettled.
Fitted Front discs, caliper carriers & calipers.
Welded up engine mounts, Welded steering extension. Painted mounts & extension. Fitted mounts & extension.
Took lots of Photos (OK 8 photo's) and added them to my archive. Between start & finish I drank 20 bottles of Grolsch , hung up my CTAutoparts calender (February is VERY pleasing) & had a really good clean out of the Garage. I can almost see the floor now.
Ho hum back to work on Monday.
posted on 4/2/07 at 07:02 PM Reply With Quote
Hope the missus approves of the calender
smdl
posted on 4/2/07 at 07:21 PM Reply With Quote
Nice work!
How do you work around the lower chassis tube being between the pedals and the master cylinders? Doesn't that tube get in the way? I'm trying to figure the best way around that now.
Thanks,
Shaun
richard thomas
posted on 4/2/07 at 07:55 PM Reply With Quote
Nice one!!
Ready for Newark this year??
Rich.
jollygreengiant
posted on 4/2/07 at 08:01 PM Reply With Quote
Thanks,
Shaun
No, no problem at all there.
Picture from inside the car
jollygreengiant
posted on 4/2/07 at 08:03 PM Reply With Quote
And from engine bay side.
Cylinders sit above the lower rail.
jollygreengiant
posted on 4/2/07 at 08:04 PM Reply With Quote
Originally posted by richard thomas
Nice one!!
Rich.
Yep that would be nice, But I'm making no promises.
smdl
posted on 4/2/07 at 08:12 PM Reply With Quote
Thanks -- my pedals pivot lower than yours, and the master cylinders are designed to attach directly to the pedal box. I'll have to either raise the pedals up, or find some clearance for the masters.
Sorry to hijack your thread. Again, Nice work!
Shaun
