smdl
posted on 23/4/07 at 03:28 AM |
Anti-Roll Bar
I am using a set of MNR book wishbones, and am planning to use a front ant-roll bar. Has anyone here use one on their car? If so, how have you
attached the links to the lower wishbone?
Thanks,
Shaun
zetec
posted on 23/4/07 at 03:50 AM |
Like this...
![](/galpreviews/a544701-Picture 001.jpg) ![Rescued attachment Picture 001.jpg](/gallery/a544701-Picture 001.jpg) Rescued attachment Picture 001.jpg
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
smdl
posted on 23/4/07 at 04:49 AM |
Unfortunately, the track rod obscures the part I wanted to see, but it looks like you have just used a longer bolt through the lower damper
mounting?
Thanks for your help!
Shaun
zetec
posted on 23/4/07 at 05:55 AM |
That sort of thing.
Mr Whippy
posted on 23/4/07 at 07:47 AM |
thats cool, is the bar off a donor or is it custom?
clutch_kick
posted on 23/4/07 at 12:02 PM |
What are the sort of benefits of an Anti-roll bar on the seven? The suspension is already quite stiffish.
What sort of setups work best?
smdl
posted on 24/4/07 at 01:57 AM |
Thanks, again.
By the way, I really like the work that you have done on your car. As a matter of fact, your car is the one that has inspired me in my project more
than any other. Definitely the nicest interior that I have seen so far!
Shaun
zetec
posted on 24/4/07 at 06:09 AM |
Thanks mate. I got the ARB from MK as a kit. They were fitting them to their Spanish race series cars.
I try and run with the front suspension softish due to the crap local roads and I hope the ARB means that it doesn't roll too much...which it
don't!
smdl
posted on 25/4/07 at 03:26 AM |
Thanks for the info. I'm going to see if I can find an appropriate one locally, but may check with MNR or MK if I can't.
I find it interesting that your ARB is rear-mounted. All of the ones that I have seen have gone across the front behind the nose cone. I'll
have to take a closer look at my chassis...
Shaun
