Author: Subject: M10 Bolts with Holes
edspurrier
posted on 7/6/08 at 09:42 AM Reply With Quote
HI - looking for some M10 bolts with wiring holes - after making a lot of heat and smoke trying to drill some myself, where can I buy a pair to finish my indicator extensions?
Ed
worX
posted on 7/6/08 at 10:12 AM Reply With Quote
I made some for PaulMW for his SVA.
If you drop him a line to see if he's still got them you may get lucky!
posted on 7/6/08 at 10:38 AM Reply With Quote
My first question is why?
Any thread lock will do a more than adequate job - Loctite 242 is what we have used on most things as it is anti-vibration and allows for disassembly...
Quote from Website:
LOCTITE® 242® is designed for the locking and sealing of threaded fasteners which require normal disassembly with standard hand tools. The product cures when confined in the absence of air between close fitting metal surfaces and prevents loosening and leakage from shock and vibration.
Suitable for applications on less active substrates such as plated surfaces, where disassembly with hand tools is required for servicing. The thixotropic nature of LOCTITE® 242 ® reduces the migration of liquid product after application to the substrate.
HTH - Steve
indykid
posted on 7/6/08 at 10:46 AM Reply With Quote
Quote from Website:
HTH - Steve
eh? i'm confused.
is this in response to a different thread?
tom
Paul (Notts)
posted on 7/6/08 at 10:56 AM Reply With Quote
see other post
givemethebighammer
posted on 7/6/08 at 11:10 AM Reply With Quote
Get some mild steel ones from somewhere like B+Q, I drilled some out when I made my extensions for the SVA. I'd imagine drilling a high tensile bolt could be quite a task.
ps use cutting oil / grease and a slow drill speed too makes a real difference on the heat generated.
big_wasa
posted on 7/6/08 at 12:02 PM Reply With Quote
Where in the world are you I am sure some one local will give you a hand ?
Paul (Notts)
posted on 7/6/08 at 12:11 PM Reply With Quote
u2u me an address and I will post you a couple of m10 25mm long bolts with a 5mm hole drilled throught them.
posted on 7/6/08 at 12:36 PM Reply With Quote
Make sure that the thread pitch is correct - the M10 threads you get in B&Q and similar are metric coarse, which is what's most commonly used.
My indicators were M10 FINE, very roughly twice as many threads per cm (nearly said threads per inch!).
In other words - just check before you go out and buy anything.
grub
posted on 7/6/08 at 12:54 PM Reply With Quote
Quote from Website:
HTH - Steve
steve i dont think his on about lock wiring oare ?
posted on 7/6/08 at 04:59 PM Reply With Quote
Quote from Website:
HTH - Steve
I know - but it's funny
