New Topic New Reply
Author: Subject: Crossflow to Type 9 gearbox query
dwyer
posted on 27/11/07 at 08:52 AM Reply With Quote
I am sure this question has cropped up before..
I need to fit a type 9 gearbox to my crossflow but wonder which is the correct bell housing. The standard 4 speed Escort gearbox which is currently attached does not have seperate bellhousing. Does the standard Sierra one fit the crossflow or is there an Escort version which is seperate?
Hope this waffle makes sense!
Thankyou
Simon
GazzaP
posted on 27/11/07 at 08:54 AM Reply With Quote
The standard bell housing that comes with the type nine will fit.
Gary
www.gmpmotorsport.co.uk
posted on 27/11/07 at 03:57 PM Reply With Quote
But is ridiculously heavy! Get an RS2000 alloy bellhousing if possible.
posted on 27/11/07 at 06:52 PM Reply With Quote
Probably better to use a type 9 from the smaller petrol engined Sierras as the input shaft and bell housing are shorter. You will need to change the clutch as well .
dwyer
posted on 28/11/07 at 05:38 PM Reply With Quote
Thanks for your help again guys..
Simon..
New Topic New Reply
