Hi there!
I have trial fitted my 954RR engine in the chassis. The sump on the engine is of an uneven shape similar to this:
As I want to keep it as low as possible. I was wondering if there is an aftermarket shorter sump aviable for the 954RR engine?
Andy at AB Performance is the man to speak to he does a nice billet sump and everything else to get this motor to work.
Have you got injectors in the airbox too? They also cause issues.
The injectors are within the throttle bodies not in the airbox.
Hi
you should find email in your in tray re the sump
we do a complete set of install parts for the 954, billet low level sump, baffle plates, bellmouths, power commanders and sprocket adaptors - in fact
pretty much everything to get one into a car
let me know if we can be of assistance
regards
