1600 crossflow sump
mike2704 - 20/8/23 at 10:37 PM
Hi been looking for 1600 crossflow sump for a while now ebay listing over £150 cant afford that can anybody please help
MikeR - 21/8/23 at 01:01 PM
You do find some "new" sumps for 20 to 50 quid. If been told repeatedly they don't fit. Curiosity got the better of me. They don't fit. But if you're desperate and handy with a welder you could cut it up and use it as the basis of a sump. It would be a lot of work. None of the bolt holes along the side line up and it's a bit shorter. May fit an xr2 and probably fits a Valencia.
mike2704 - 22/8/23 at 12:12 PM
Thanks for the reply I might remove sump and see if I can cut and fabricate my own bowl haven't welded for a while so this should be interesting.
rusty nuts - 22/8/23 at 07:29 PM
Tack it up and get someone to do it for you if your not confident in your welding
perksy - 24/8/23 at 08:07 PM
1300 xflow will fit but you'll need to be 'creative' with a hammer on the sides of it to give clearance for the big end caps
