Getting flaking paint off fibreglass
RK - 23/5/09 at 01:17 AM
As in title. I used some thinners, and I get about 1mm square off at a time. There must be a faster way. Ideas welcome as usual! Thank you in advance.
thunderace - 23/5/09 at 09:06 AM
i would stick with thinners as sanding will take just as long.
Mark Allanson - 23/5/09 at 09:32 AM
What sort of paint is it? Different paints, different answers
liam.mccaffrey - 23/5/09 at 09:35 AM
soda blasting
tomgregory2000 - 23/5/09 at 10:42 AM
Get some paint stripper from a chandlery as they have been designed to be safe on gelcoat, but yes different paint different answers
HAL 1 - 23/5/09 at 01:35 PM
you could try acetone, it'll shift all sorts of paint off all sorts of surfaces ( don't use on clear plastic ) shouldn't damage gelcoat but as all instruction leaflets say 'try some in a place that won't be seen'
RK - 23/5/09 at 01:55 PM
Hey my grandmother came from Bolton. Never been myself, but some family in Blackpool now, that I don't know very well. ANYWAYS, it's enamel. Thanks for the suggestions so far!
twybrow - 23/5/09 at 03:10 PM
Enamel? That will be tough to get off. If you are respraying anyway, why not just abraid everywhere to key it up, then spray? If it has to go, I would get the random orbital sander out (and I dust mask!).
HAL 1 - 23/5/09 at 04:46 PM
Next time you're passing through let me know and i'll put kettle on
