Installed a Girpro -ATRE gear indicator this morning. So simple to fit with very clear instructions. Just had to remove 4 wires from oem plugs
transfer to Girpro plugs, connect to the battery and it worked straight away. No sensors to fit. If everything on the car had been that simple.
Much more comforting see what gear you are in, not noticed much difference on the atre yet though.
Sounds good. Does this mean you are planning on driving your car sometime rather than trailoring it
Originally posted by DarrenW
Sounds good. Does this mean you are planning on driving your car sometime rather than trailoring it![]()
sounds cool
lost me on the oem plugs bit though
Originally posted by richardh
sounds cool
lost me on the oem plugs bit though![]()
