can anybody help me with which alternator to use on my pinto engined mac#1. there is very ltlle clearance between the steering shaft and the location for the alternator, any help would be a great help as this is causing me major headaches !
I've used the Nippon-denso alternate, which I think came from a daihatsu charade - tiny in comparison to the system pinto one....
thanks for that,time to go and look for one.................did you use the ford mounting or fabricate your own
I run the same car, I use the standard alternator with a modded bracket.
