Well Ive just got back from a blat and on the return journey dropped in on a weighbridge I know of.
The result - a svelt 540kg
I think I'm going to get that double checked at a different weigh bridge as it seems a bit light for a pinto powered ZR.
But until then YIPPPEEEE. I was expecting it to start with a 6.
Surely it cant be 60 kg out 10%?????
isnt it illegal if the scales arent correct?
trading standards and all that mallarky
Not too suprising - with half a tank of fuel, my MK which I would imagine is similar to yours was 625kg but that was with a screen and more in the way
of roll over protection and I have upholstered seats too.
If your tank was empty that would also help.
Mark
It wasnt empty but it wasnt full too. I reckon there was at least 10 lites in there, possibly more.
Also weigh bridge accuracy - can be +/- 50 kg. remember they are for weighing lorries which weigh 38 tonnes or so which is 0.1% error at 38 tonnes.
Its like if you want to weigh out 1/2 lb flour for making pancakes, you wont get it very accurate on bathroom scales cos they are meant for weighing
15 stones or so.
Mark
bloody hell lads your making him depressed
he thought he was onto a good weight for a minute then
Sob sob.
I can see this is going to turn into one of those similar to rolling road BHP claims.
"Mine was done on X's rolling road in boiling hot summer and my engine was runnin rich an I still got a squillion brake from my festa"
I reckon that 540 is a bit light but I would still be confident that it will be under 600 Kg
Was it a weighbridge that VOSA use to pull wagons off the motorways for spot checks? Does anyone know if these are ever used to weigh caravans and
small trailers to see if they are overweight or if the car is big enough to tow them. If so that would suggest they are also accurate down to 2 or 3
tonnes. I guess the other nice thing to know is how they are calibrated - ie right through the range in increments or only at a specific point?
I wonder if a local coal yard with scales might be more accurate. The wagons weigh a lot but they need to be accurate so they can charge correct
amount for goods. they may be accurate in the middle of their range tho rather than at the lower end. A similar analgy is when using micrometers - in
that you have to calibrate them close to the measured size to get the accurate result. Next time find a freindly low loader driver so you can stick
car on the back............. perhaps not.
I really hope it was somewhere near seeing as mine is almost identical build.
At SVA mine was weighed front and rear seperately at around 650Kg. I asked the tester about accuracy for overall weight and he said they used to have
4 wheel scales which gave similar result - although i bet in reality they were 2 seperate sets in one unit to measure the axles seperately. There must
be a recognised accurate way to check car weight.
Not if C&E check it they can't, they would close it down and fine the operator. The one at the steel plant I worked at was never more than
20kg out. The overseas drivers used to unload their contraband before they weighed in so as not to throw their tare out.
[Edited on 10/2/06 by Peteff]
Yeah, if it was accurate to 20kg then I'd be max weight of 560kg and min of 520. If it was accurate to 50kg I'd still be under 600kg
I fiddled with the level sender last night to get it to properly read full and empty. I measured the tank and put a dip tube in to see how much fuel
was actually in there and by my calcs there was 14 litres
According to a google result 1 litre of petrol weighs 750g or .75 kg which means that I had 10.5kilos of fuel in when I went to get weighed.
My fuel gauge was severly underreading and when it said nearly empty was actually nearly half full.
Well Ive had her weighed again. This time it was on my local British Sugar's weigh bridge that is calibrated to +/- 20kg.
With half a little over half a tank of fuel she weighed 580kg. After the last time I decided to see how much extra I added on to see how big the
change of weight was compared to what I actually weigh. I weighed myself as soon as I got in and I weighed 97kg. The weighbridge said me & the
car weighed 680kg which means that it is well within the +/- 20kg tolerance and is overreading slightly.
Chuffed - too right. Pinto powered Type ZR with half a tank of fuel (15 litres min = 11.25kg extra weight) = 580kg. Whoopie
That sounds good Jos. I know my car is very similar spec with no trim, screen and bare shell seats so full of fuel will be close enough to 600Kg. Im
quite happy with that.
LMAO at the comment you or the factory made regarding my daily driver on M1MOC
Very true!!!
I had a nightmare the other day. Lost my clutch! Lock nut came off the pedal and the clutch cable loop dropped off. Easy fix, longer bolt, new nyloc
and a plain nut locked on for good measure. Id recommend you taking a look to check yours. Its a pain to fix roadside. I tried to claim under warranty
off the manufacturer but got no joy. Customer service is crap - (ie me!!!). my mate towed me with his landrover on a 6' strap - bugger was going
40mph - quite scary, i couldnt see a thing and had to brake him down when approaching junctions, this tested the brakes out anyway!!!! Have you ever
tried to slow down a 2ton monster with a 7??????
Funnily enough Darren, Ive also had the nuts fall off the clutch cable at the pedal when I was finishing off my running in miles. Ive also put a longer bolt on with double nuts locked together & a nyloc just in case.
That makes me fell better then. Nice to know im not the only numpty!!!!!! I blame myself, nyloc wasnt engaged fully on the bolt. I tried to get wawy with using as short a bolt as possible so there was no chance of the free end fouling anything. I was probably meant to keep an eye on it but forgot!! What made it worse was that it was lashing down on Friday when it happened. Boy do those Landrovers kick up some spray!!!!
