Hi. Currently overhauling a Type 9 gearbox. There is a large circlip (the countershaft gear cluster retaining circlip) which needs to be removed. The
largest circlip pliers I have are 7", and look no-where near up to the job. Anyone removed this bad-boy, and if so with what type of circlip
pliers?
I don't have one to hand, but I believe there are books on the Type 9 g/box - maybe they give directions for what tools you may need?
One other avenue would be to ask a transmission specialist who has worked on or rebuilt the g/box. Again, they may know the way around it.
ETA...ebay has quite a few different size circlip pliers for not a lot of money - worth a look as it might be what you need!
[Edited on 19/1/16 by nick205]
https://www.dropbox.com/s/4i6b4ll85wqsfu2/'N'_Transmission.pdf
not my link, but you don't need to be sign up/in.
I can't recall and will check tonight, but the Haynes manual may have some info as well.
I stripped down and rebuilt my type 9 last year (pics in my photo archive if you are interested). I had to buy a cheapish set of larger circlip pliers
to remove the larger circlips. I'll have a look and see how big they are and let you know.
Pete
These worked fine for
me the last time i did a type 9, you may also need some of
these for the bearing
retaining snap rings, they can be a bit tricky trying to slide them over like a piston ring.
There are cheaper alternatives, but the knipex tips don't bend or round out the circlip ears like cheap ones can.
You may need a slim puller to remove 5th gear from the layshaft, it is usually tight and there is very little room behind the gear to fit normal 3
legged pullers behind.
Dave
Thanks - It's the Haynes manual I'm following and it just has a pic of a pair of circlip pliers. can't see mention of any specific size of tools.
Agreed, but never rebuilt a gearbox before, and although complicated I assume this is about as simple as they come. Always think it's easier to diagnose and fix something if you've ripped it apart. This way I'll end up with a partly reconditioned t9 that I will have a certain amount of confidence in (assuming I can get this darn circlip removed) ;-)
One further question...given the cost of a Type 9 g/box is it worth rebuilding? Could be cheaper to buy one and chuck it in.
Originally posted by Pete Jordan
I stripped down and rebuilt my type 9 last year (pics in my photo archive if you are interested). I had to buy a cheapish set of larger circlip pliers to remove the larger circlips. I'll have a look and see how big they are and let you know.
Pete
Originally posted by obfripper
These worked fine for me the last time i did a type 9, you may also need some of these for the bearing retaining snap rings, they can be a bit tricky trying to slide them over like a piston ring.
You may need a slim puller to remove 5th gear from the layshaft, it is usually tight and there is very little room behind the gear to fit normal 3 legged pullers behind.
Dave
