Rover K engine inclination
drt - 16/5/18 at 04:34 PM
Dear chaps
Regarding my project car... I'm fitting a rover K engine (Rover 45) and in my application it would be better if I could have the engine
about 10-15 degrees more slant over. See pictures
I'm under the impression that the sump normally is level in the original car.
Will the engine agree with this ?
Do i need to alter...the sump or oil pick up ?
Will oil in the head accumulate or drain too quickly?
drt - 16/5/18 at 04:54 PM
Just measured 11,1 degrees from horizontal (bottom sump)
mackei23b - 17/5/18 at 09:08 AM
All the Caterhams run inclined. I've just measured my engine in the Caterham at the cam cover and it is inclined 14 degrees. That said it has a Caterhams run their own wet and dry sump systems that were designed for this inclination.
Ian
drt - 17/5/18 at 01:58 PM
Thanks Ian
I'll modify the sump a bit... should work then ^^
