Flamez
| posted on 29/12/10 at 09:21 AM |
Water expansion bottle
I am currently running a zx10r engine with a yamaha r1 radiator. I have the overflow from the rad neck running to waste. Do others use an expansion
bottle? Or like wise run to waste?
my build mac1motorsports
jase380
| posted on 29/12/10 at 10:50 AM |
You got that engine in yet Phil ?
MakeEverything
| posted on 29/12/10 at 10:56 AM |
Yes, use an expansion bottle with a breather. When cold, the bottle should be half full, and the hose to the system from the bottle should be at the
highest point to collect the air.
Kindest Regards,
Richard.
franky
| posted on 29/12/10 at 10:57 AM |
with an expansion system its not got to be at the highest point if you've got a header tank on the radiator.
Flamez
| posted on 29/12/10 at 11:04 AM |
Yep engine in, just need to refit the loom and cooling system, I'll have. Crack tomorrow. You got me thinking about the exhaust too Jason after
seeing your set up very nice. It would be good to know what noise you are running at though.
jase380
| posted on 29/12/10 at 11:37 AM |
All i can say on the noise front is firkin loud !!, one of the benefits of having the can 3 feet from your ear on the drivers side. It made 146.2 bhp
at the wheels on the rolling road using the titanium bike manifold and standard airbox ( with a power commander ). Dont know how that compares with
the aftermarket manifold and airbox ?.
MakeEverything
| posted on 29/12/10 at 11:47 AM |
Good point, though i because i dont have a header tank i assume that no-one else does either!
Kindest Regards,
Richard.
cliftyhanger
| posted on 29/12/10 at 12:13 PM |
If the system is designed to "suck back" through the rad cap when it cools, then yes, run a hose into a bottle that will catch the fluid,
and as it cools it will suck it back. It should also bleed any air too.
The catch bottle needs to be vented, and the hose run to the bottom, and a few inches of rad fluid when set up.
However, if the system does not allow suckback, leave it to find its own level.
*AL*
| posted on 2/2/11 at 08:39 PM |
On my R1 engined MAC i do have an expansion bottle, the car was factory built.
mr_pr
| posted on 6/2/11 at 09:06 PM |
Get an expansion bottle. I have just installed mine as I was having to top up coolant before almost every run. Now, no longer an issue!
My Build Progress
