Author: Subject: First Post
DarrenW
posted on 5/9/05 at 02:49 PM Reply With Quote
First Post
Many Thanks Chris for setting this section up. Top guy.
I have ran into a side light savage switch wiring problem during my ZR build.
What colour wires have other Mac#1 builders connetced to term 1 of the sidelight savage. Ive used grey and have a problem. All was well when i had a switched live to terminal 1. When i changed to terminal 2 the power not only lit the sidelights but it also backfed the dash - this meant the DD2 was powered up and i could start the car - all without having the ignition key anywhere near the car - not good.
The problem lies with the wire i have used as the sidelight feed - problem is i dont know what other one to use?
[Edited on 5/9/05 by DarrenW]
mookaloid
posted on 5/9/05 at 02:58 PM Reply With Quote
I don't know what the answer is to your problem but congrats on being first to post here
Mark
DarrenW
posted on 5/9/05 at 03:01 PM Reply With Quote
Cheers Mark - someone had to do it. Maybe the first post should have been how i managed to get a large flame shooting out of my carb at the weekend and what the small flame afterwards looked like down the carb body!!!!
(Facet redtop being too powerfull is the cause - mechanical pump is the fix)
speed8
posted on 5/9/05 at 03:02 PM Reply With Quote
I was wondering when this would happen as there seems to be quite a few Mac1 kits being built.
Can't help with the wiring, I assume you have one of their looms as I can't see what difference the colour of the wire would make to it working or not
DarrenW
posted on 5/9/05 at 03:25 PM Reply With Quote
i should have said that it is a Premier loom, full set of savage switches, DD2 and all Sierra stalks etc removed. Hence it would appear that i have picked up on the grey illumination wire as the sidelight feed instead of the correct sidelight feed wire. The basic question is therefore what is the correct sidelight feed wire colour and where is this located on the premier loom (for Sierra based kits)??
jos
posted on 5/9/05 at 03:35 PM Reply With Quote
I'll look at mine in 10 minutes and call/text you to let you know
mac1
posted on 5/9/05 at 04:08 PM Reply With Quote
Hi Darren, I'll explain what to do on Thursday when you call in, congrats on being the first to post, shouldn't you be working??
Mark
Triton
posted on 5/9/05 at 04:57 PM Reply With Quote
Took yer time Mark.....
Mark
posted on 5/9/05 at 11:12 PM Reply With Quote
This should be a sticky Chris.
Try a white one ?
[Edited on 5/9/05 by Peteff]
